IACV Woes
Old Feb 4, 2009 | 12:57 PM
bandit080000's Avatar
Icon2 IACV Woes
Hey everyone,
So a few months ago I swapped out my d15 for a d16 with a stage 2 cam, p29 pistons, etc. I've been using the P06 ECU since the swap. Today, I got my P28 back from being chipped. I plugged it in and now I'm throwing a CEL 14.
Is the wiring for the IACV different on the p28 that it would be the p06?
When I run the P06, the car runs great with no CELs. However, when I use the P28, it idles REALLY low almost to the point of snubbing out.
Anyone have any ideas?
Old Feb 4, 2009 | 08:27 PM
Default Re: IACV Woes
good night bump!
Old Feb 5, 2009 | 06:37 AM
good morning bump!
Old Feb 5, 2009 | 07:11 AM
JDM-DC2-GSR-96's Avatar
I would like to know the answer to this question also....
Old Feb 5, 2009 | 09:40 AM
a little bump to go with lunch!
Old Feb 5, 2009 | 10:22 AM
phaphon's Avatar
i got the same problem.....but even though i change ecu's mines stay on i tried changin the iacv but still comes on i would like to know the answer
Old Feb 5, 2009 | 11:04 AM
So I just took the IACV off and cleaned it up.....it was filled with carbon buildup.....however, the problem still stands.
Old Feb 5, 2009 | 11:29 AM
I took it out around the block.....It'll keep idling at about 1k....however, unless you mash the pedal to the floor, it'll rev bounce at 1500 and then shoot up from there.
Old Feb 5, 2009 | 12:24 PM
i just traded shells with a buddy and i had a eg6 and now have an ek9 hatch and the wiring harness was hacked... i put my poor mans itr in and it ran like ****... i fixed everthing and soldered every wire and im throwing codes 3 + 14 so map sensor and, IACV... my question is on OBD2A at the ECU there is a positive wire, negative wire, and a signal wire for the IACV but only 2 wires at the IACV plug???? WTF where does the other wire go?? lol i really need a wiring diagram for this...
Old Feb 5, 2009 | 03:43 PM
Redbone's Avatar
yeah on OBD2a its 2 wire IACV and OBD2b is 3 wire. Check www.ff-squad.com for wiring up your shiz.
Old Feb 5, 2009 | 05:36 PM
So I guess the problem can be caused by an IACV driver corruption on a chip on the ECU. At least that's what Phearable told me.
Old Feb 5, 2009 | 07:52 PM
Redbone's Avatar
they may have ****ed up your ECU when chipping it
Old Feb 10, 2009 | 02:05 PM
phaphon's Avatar
hey i just talk to a buddy of mines and he told me to try tuning the screw on the iacv imma try it and ill update on how that goes
zccivicex
Mar 7, 2013 11:47 AM
DA is best
Feb 19, 2012 06:08 PM
K i l l a B e e.
Jan 5, 2009 12:35 PM
mousiex113
Aug 26, 2007 02:16 AM
MBlake55
Jul 11, 2006 11:20 AM
