vtec problem
Old Feb 4, 2009 | 12:09 PM
csk239's Avatar
Default vtec problem
vtec hits in first but not in any other gears (its a b16a3 with b17 tranny)...ive been told maybe the chip is set to low, maybe the wiring(i checked the wiring its good), the soliond is dirty(cleaned that), oils good. It is throwin a vss code which is code 17 could that be a problem with vtec engagin? If theres anything else i should check please tell me or if anyone else has had this problem enlightin me.
Old Feb 4, 2009 | 12:13 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: vtec problem
Hm, there is a CEL and something isn't working right.
Nah couldn't be linked at all.
It's posted many times exactly what is required for vtec engagement, search.
Old Feb 4, 2009 | 02:27 PM
schock3's Avatar
vss is needed for vtec to engage!
Old Feb 4, 2009 | 02:42 PM
0ne-Cam's Avatar
i had the same problem on my h22, just replace the vss and the problem should go away. its a little expensive for preludes but not sure on b16's, call the nearest junkyards
Old Feb 4, 2009 | 02:44 PM
gibsanez's Avatar
What ECU are you even using?
Old Feb 4, 2009 | 02:53 PM
csk239's Avatar
im usein a pr3...and my speedo works and the check engine light doesnt come on all the time the ecu flashes the code thou
Old Feb 4, 2009 | 03:23 PM
gibsanez's Avatar
Why is there an aftermarket chip in the ECU?
01em2slvr
Honda Civic (2001 - 2005)
Nov 11, 2009 12:43 PM
valentine97
Jan 15, 2008 06:30 PM
kevbo82
Oct 31, 2005 04:47 PM
tuckin15s_8315
Sep 28, 2005 09:35 PM
