bead form tool needed
Old Feb 4, 2009 | 11:10 AM
turboaap's Avatar
Default bead form tool needed
want to buy a bead form tool used if you know were i can get one please let me know befor i go and spend 400+ on one. thanks wayne
Old Feb 4, 2009 | 11:24 AM
spiceisler's Avatar
Default Re: bead form tool needed
Eastwood Company
Old Feb 4, 2009 | 11:47 AM
RedneckRicer's Avatar
you could always use the welding meathod if u are doing this for charge pipes
Old Feb 4, 2009 | 12:43 PM
yellow_weapon's Avatar
i found this linked on another forum i go on,
http://www.dsmtuners.com/forums/arti...ler-pipes.html
i made one up and it does actually work quite well
Old Feb 4, 2009 | 02:36 PM
Dren's Avatar
Cheap and effective, I might have to try it. I've been looking at a bead roller for awhile but couldn't bring myself to spend the cash.
Old Feb 4, 2009 | 02:58 PM
narfdanarf's Avatar
I was dickin off at H-F the other day and saw this. Thought about getting it, but decided against it due to wife nagging.
http://www.harborfreight.com/cpi/cta...emnumber=93364
Old Feb 4, 2009 | 03:33 PM
redboost10's Avatar
we have the hf one and then we bought an electric one, ended up getting rid of the elctric one.
way more control with the manual ones and i think they do 10 times better of a job.
we usually just use ours for tin work for tube chassis cars, but have did osme 16g ic tubes as well.
Old Feb 4, 2009 | 04:56 PM
Bakeoff's Avatar
That's the 12". I have an older 18", I think... It works well for thin sheet. Anything thicker than 18g and it flexes. I bolted up a chunk of angle iron and it worked really well, but I'll be making a frame out of 2x2 pipe and really take advantage of it at some point. Not a bad tool for the money.
Old Feb 4, 2009 | 06:32 PM
Autoworks's Avatar
vansantent.com
Old Feb 4, 2009 | 07:11 PM
turboaap's Avatar
I have the 18in bead roller for doing sheet metal it will do a bead on piping but it will be alot cleaner and faster with the bead form but I thought I would check to see if anyone was selling one befor I spent 4xx on one. But thanks for all the info guys.
Old Feb 5, 2009 | 05:47 AM
jweller's Avatar
Those harbor freight ones look pretty simple except for the dies. If I were to make the dies on a lathe, what kind of steel would I need to use, and would they need to be heat treated?
I know it's probably more cost effective to buy them, but I want to learn to use the lathe and this seems like a pretty simple project to start with.
Old Feb 5, 2009 | 07:40 PM
Top Ramen's Avatar
I bought the HF one years ago and just Mig'd on a triangulated brace out of square tube. It works fine.
There are a couple of threads on this mod on the metalmeet forums.
.RTErnie
Welding / Fabrication
39
Mar 26, 2006 07:49 PM
SpeedMonkeyRacing
Apr 12, 2005 08:35 AM
Want2race
63
Feb 12, 2005 08:38 PM
onelowchef
Jan 19, 2005 09:31 PM
