alternator change help.
Old Feb 4, 2009 | 10:34 AM
jeck_bar2's Avatar
Default alternator change help.
Does any b series alternator fit my b17a1? Or I have to find that is only for b17? Need help.. thanks!
Old Feb 4, 2009 | 11:59 AM
neardon's Avatar
I'm a Jackass
Default Re: alternator change help.
Any b series obd1 vtec is going to fit so a del sol vtec (b16) will fit.
On a side not, if your alternator just went out they have brushes inside you can replace and it will run like new. Thats usually what goes bad inside them and they are less than 10 bucks at your local auto store. A lot cheaper than a whole alternator.
Old Feb 4, 2009 | 01:34 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If you can get the alternator apart. I tried to take one apart once to rebuild it, and never could get the housing to separate.
Old Feb 4, 2009 | 09:58 PM
jeck_bar2's Avatar
Ok thanks so much! Got one last question something is pulling my battery down so bad. I have to jump my car whenever I need it. That's why I'm thinking its my alternator. But my battery I relocated at the trunk so I might thinks also its maybe a ground wire or something.. what tests can I do to check if alternator is bad?
Old Feb 5, 2009 | 02:02 AM
Cameron60's Avatar
I usually do this...
1-Start your car (jump if needed) and let it run for a lil..
2-Undo the ground from the battery. If the car dies immediatly id say it was the alternator.
Old Feb 21, 2009 | 05:08 PM
jeck_bar2's Avatar
Thanks!
p3p69
Sep 12, 2013 08:15 AM
Honda_Tech01
Aug 2, 2008 11:06 AM
obuhmyuh
May 28, 2008 03:27 PM
allanonjj
Apr 14, 2007 03:08 PM
bonta-kun
May 12, 2003 06:08 PM
