New Shocks and Springs Install
Old Feb 4, 2009 | 07:14 AM
guitarguru87's Avatar
Default New Shocks and Springs Install
I bought a set of KYG GR-2s and eibach pro-kits for my 88 crx dx. The car has like 295000 miles on it and I know the suspension is not anywhere near stock. Is there anything I should look out for to make sure my install goes smoothly? Is there anything else I need to buy besides the shocks and springs like bushings or something?
Old Feb 4, 2009 | 07:22 AM
90crxdriver's Avatar
Default Re: New Shocks and Springs Install
get a can of PB blaster and soak all the bolts a few times and that will make it a lot easier to get them out. good luck hopefully none of the bolts break on you like they did on mine.
Old Feb 4, 2009 | 07:32 AM
90_EX_Civic's Avatar
X a million. soak, for a week. PB it everyday, drive it everyday. then hopefully the bolt wont be seized up(lower rear control arm bolt) and break on you when you go to remove.
Old Feb 4, 2009 | 07:58 AM
EL Vap133's Avatar
First thing I thought was the rusted bolts too! Just make sure you have the tools necessary and hopefully you won't run into any rusted/warped/stripped bolts.
ShinotakuX
13
Sep 12, 2007 10:13 AM
isuhonda83
Sep 22, 2004 05:44 AM
Heinz57
23
Jan 17, 2003 12:22 PM
s0liDyNe
Sep 13, 2002 07:58 PM
Carp
Apr 3, 2002 01:13 PM
