Noise coming from transmission
Old Feb 4, 2009 | 06:48 AM
aemintgsr's Avatar
Default Noise coming from transmission
Alright after i installed my gsr swap back in my teggy with a new Competition Clutch kit stage 2 and Competition Clutch flywheel(street) i had realized that my idle was high so i turned it down to specs, while it did that there is a loud knocking noise coming from the tranny. Then after driving it i realized that once i step in the clutch the noise is gone, and also when i give it a little bit of gas too.
Old Feb 4, 2009 | 07:14 AM
mouab18c1's Avatar
Default Re: Noise coming from transmission
is it ticking? im sure its your throwout bearing
Old Feb 4, 2009 | 07:25 AM
aemintgsr's Avatar
What do you mean by sticking?... the throwout bearing is brand new. and when its idling and i step on the clutch pedal i can feel some vibration on the pedal...
Old Feb 4, 2009 | 08:32 AM
mouab18c1's Avatar
ticking!!not sticking....mine does the same...mine ticks but when i step on the clutch pedal it stops..and yes i can feel vibration on my pedal also...i know mines going out but for yours since its new hopefully you installed it properly
Old Feb 4, 2009 | 08:47 AM
aemintgsr's Avatar
Yes its ticking, yes thats exactly what its doing. Yea its new it came with the kit. its pretty easy to install just slide it in right??
Old Feb 4, 2009 | 08:49 AM
mouab18c1's Avatar
well it could be defected..ahaha but who knows...for now im sure its the throwout bearing
Old Feb 4, 2009 | 08:53 AM
aemintgsr's Avatar
F@*k it ill just raise the idle a little! LOL
Old Feb 4, 2009 | 08:59 AM
mouab18c1's Avatar
that wont do anything....it should be fine...mines been doing it for a couple months now...my clutch doesnt slip or anything...i've took it down the track a few times..so you should be good..its just annoying
Old Feb 4, 2009 | 09:07 AM
strtrcr77's Avatar
mine made a similar noise awhile back, turned out being the input shaft bearing i just drove till it broke into pieces
Old Feb 5, 2009 | 06:36 AM
aemintgsr's Avatar
But it didnt do it when i had it with my stock LS until i put back my GSR and a new clutch kit ???... And I just realized my DD CRX has been doing the same thing since i bought it like over a year ago!! and no problems??
Old Feb 5, 2009 | 06:44 AM
LS stretch's Avatar
did your rub grease around the parts that have metal to metal contact? for example the part of the throw out bearing that comes in contact with the fingers on the pressure plate? whenever ive done clutchs ive alwasy put some hi temp grease on that spot and on the splines of the input shaft. sounds like that could be your problem or the internal bearing structure of the throw out bearing itself could have been defective from the factory
Old Feb 5, 2009 | 07:41 AM
mark pones's Avatar
clutch chatter?
when the car is out of gear does it make racket? if you push the clutch in and it goes away it could be clutch chatter... maybe
Old Feb 5, 2009 | 08:44 AM
aemintgsr's Avatar
Originally Posted by mark pones
clutch chatter?
Its more like a ticking noise!
Old Feb 5, 2009 | 06:18 PM
94EG8's Avatar
Seagull Management
Its not the the throwout bearing. If it was it would be noisy when the clutch pedal was depressed, the only time the throwout bearing turns. Most likely either the input shaft bearing or the other mainshaft bearing went bad.
Old Feb 6, 2009 | 06:46 AM
mouab18c1's Avatar
oh yeah
Old Feb 6, 2009 | 07:42 AM
aemintgsr's Avatar
Thats when mine is noisy, when the pedal is not pressed in.
Old Feb 6, 2009 | 08:32 AM
mouab18c1's Avatar
i've heard many stories...mine only ticks when my car is parked and my clutch pedal is not engaged...i guess the only way to find it is taking it out and replacing it
Old Feb 6, 2009 | 09:00 AM
aemintgsr's Avatar
Same here!!!
Old Feb 6, 2009 | 09:39 AM
be18see1's Avatar
i'd put my money on the input shaft bearing. my gsr trans made a whirring noise until i dropped the trans and split the case. all but two or three of the ***** for the bearing were in the bottom of the case. replaced it and it's been fine since.
Old Feb 6, 2009 | 10:14 AM
mouab18c1's Avatar
lets hope thats not my case
Old Feb 8, 2009 | 05:49 AM
be18see1's Avatar
funny story. i put a new trans in yesterday and it has a bad bearing too. sweeeeet.
Old Feb 8, 2009 | 05:53 AM
IN VTEC's Avatar
Is the flywheel pilot bearing installed?
Old Feb 8, 2009 | 06:00 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Most definitely the input shaft (a.k.a. main shaft) bearing.
When your car is in neutral and you disengage the clutch, the main shaft stops spinning, which is why the noise goes away. At all other times, the main shaft spins, thus making the noise.
Old Feb 8, 2009 | 04:42 PM
mouab18c1's Avatar
doesnt that make you just wanna burn that shyt up? ahaha sucks a$$ man...
Old Feb 25, 2009 | 06:38 AM
aemintgsr's Avatar
Well i took it apart and found out that the flywheel was loose!! All the bolts were torqued down correctly but it was loose... Thumbs down for Competition Clutch flywheel and ARP bolts!!
