fender removal for a gen 3 integra DC4
I have a dc4 integra and recently a victim of a hit and run but I have searched here and team integra and cant find anything on removal of a fender what do I need to do in order to pull it off because I am planning on picking up a used fender and replacing it. thanks if you guys can help
When removing panels, or bumpers, always stary from the bottom up. Most **** u can figure out by a good look at what you wanna do. For the fender, start by removing the screws on the front of the sideskirt. This will allow you to bend the skirt down to reveal 2 10mm bolts at the bottom of the fender. Next remove the screws holding your plastic wheel well apron and locate the 10mm bolt by the front off the fender. Next if you open your door all the way you'll see another 10mm bolt at the top inside by the door hinge. You'll need an extension to reach this unless you use a wrench. Then pop your hood and remove the 3 bolts along the inside of the fender. Good luck and always remember if ur not sure on your honda, its prolly a 10mm
fstgsr
Jun 14, 2005 09:23 AM
