'67 Mini Cooper Header
Old Feb 3, 2009 | 07:04 PM
Mikes1098's Avatar
Default '67 Mini Cooper Header
I am getting ready to build a header for my old Mini Cooper. There are 3 primary runners that will tie into a single runner which will lead to the turbo. The primary runners will be 1.25". Does anyone know how to properly size the secondary runner?
Here is a picture of the car if anyone interested...
Old Feb 4, 2009 | 03:53 AM
spiceisler's Avatar
Default Re: '67 Mini Cooper Header
Put a B16 in it!
Old Feb 4, 2009 | 04:35 AM
weiRtech's Avatar
OG Fabricator
www.burnsstainless.com
they should be able to give you some direction.
Old Feb 4, 2009 | 10:39 AM
GTibunny16v's Avatar
When you say size are you talking about the length of the runner? 3 cyl should be pretty easy to make a turbo manifold for.
Old Feb 4, 2009 | 10:43 AM
redboost10's Avatar
more than likely the step is no more than 1/8". but like mentioned, burns has a form to fill out and they will set you up.
Old Feb 4, 2009 | 11:14 AM
spiceisler's Avatar
Ok. If I remember correctly the head had the intake and exhaust on the same side (as shown here):
The ports on the outside and the middle are the exhaust and the inner ones are the intake.
The original headers have 3 runners, 1 & 4 being separate and 2 & 3 combined, like so:
I think you could use three runners equal size and make a collector as if the car was a 3-clyinder. You'll be fine!
I don't know if you are a MINI purist but for what it's worth I would put a DOHC Vtec B16/B18 and turbo that, as shown here:
Thread: http://www.16vminiclub.com/forums/viewtopic.php?t=15347
I think you'll have a more reliable/tunable car and the end result, horsepower-wise, would be greater.
Disclamer: All pics are borrowed and shown for reference.
Old Feb 4, 2009 | 04:11 PM
Mikes1098's Avatar
Thanks guys... I have been all over Burns SS website, never thought of simply asking them. But I think I have changed the design so that it does not matter. Originally, I was going to have the three runners tie into a single one then go to the turbo. After playing around, my buddy stumbled on a sweet equal length header design that will allow me to run all 3 runners to the turbo. By the way the turbo will be mounted on the side of the engine.
Spiceisler, your mini looks awesome. I am not necessarily a Mini purist and I contemplated putting a busa engine in mine... but the shell was so solid I could not big myself to cut it. If I ever buy another one it will get an engine transplant of some kind.
Old Feb 4, 2009 | 04:45 PM
Bakeoff's Avatar
**** the Mini. Lets see the Triumph! lol
Old Feb 5, 2009 | 05:03 AM
spiceisler's Avatar
The mini is not mine! It belongs to user "joecool" on www.16vminiclub.com I just borrowed his picture for reference.
Old Feb 5, 2009 | 03:04 PM
TunerN00b's Avatar
I always hated how the ports are on the same side of the head on my Triumph. Even worse that both manifolds are held in place by only 6 studs and what looks like a wind nut to hold both manis with each nut (makes for great fun when the intake and exhaust manifold flanges are different thicknesses)...
Old Feb 5, 2009 | 07:39 PM
Mikes1098's Avatar
LOL!!!! The TR6 was my first project.
It got a 302 with a T5 trans and some AC. The few extra horsepower makes it a blast to drive.
Having the intake and the exhaust ports on the same side definitely makes it interesting when laying out the header. The real intersting thing is the siamesed center exhaust port. #2 and #3 exhaust ports tie together in the head and dump out or the single port in the center.
Old Feb 5, 2009 | 08:28 PM
A 5.0 in a Triumph. Thats the only way that thing could run reliably. Tuning the carbs on stock Triumphs makes me wish I was hitting my nuts with a hammer instead.
boostedgsr1234
Welding / Fabrication
Jan 1, 2009 06:08 AM
crxsteve
Jan 16, 2007 11:18 AM
KC GSR
May 31, 2002 08:54 PM
nerdish
Mar 3, 2002 07:10 AM
Ryuji
Jan 1, 2002 07:17 AM
