Can someone identify this cylinder head casting number??
Old Feb 3, 2009 | 05:29 PM
vtecman's Avatar
Icon2 Can someone identify this cylinder head casting number??
My friend and I were trying to find out what year head is on his gsr motor and i wanted to know if anyone knows how to read the honda casting numbers stamped into the head, the engine is a b18c1.
His head reads 86 11 27 06
Thanks
Old Feb 3, 2009 | 05:49 PM
Shawn C's Avatar
In The Garage
Default Re: Can someone identify this cylinder head casting number??
you sure its not a 98 upside down?? thatd be my guess...
Old Feb 3, 2009 | 06:27 PM
vtecman's Avatar
i am pretty sure it started with 86
Old Feb 3, 2009 | 06:37 PM
j_bizach's Avatar
ther was just a post on how to identify the year the block was manufactured.
Old Feb 3, 2009 | 06:40 PM
j_bizach's Avatar
https://honda-tech.com/forums/showth...998&highlight=
Thats the thread and your reading it wrong as they deff. wer not casting vtec heads 1986
Old Feb 3, 2009 | 07:02 PM
vtecman's Avatar
ok because i just looked at it and it says 8l6 maybe it is upside down and i means 98?
Old Feb 3, 2009 | 07:15 PM
ruffrhyder's Avatar
look at the number directly above cylinder 4 exhaust port. That is the year the head was cast. The first number on the block indicates the year the block was cast according to the first year that series of blocks were made. For examble a GSR block number that starts with a '1' would be a 94 block since 94 was the first year B18c1 were made. A block code starting with a 2 would be a 95 block, and so forth. The folloing numbers indicate the block's build sequence. For example a block code 1000001 would be the 1st B18C1 block built in 1994.
Old Feb 3, 2009 | 07:19 PM
vtecman's Avatar
so if the very first digit on the motor i am looking at starts with 8 so that would mean its a 2001 gsr?
Old Feb 3, 2009 | 07:29 PM
ruffrhyder's Avatar
Yeah you may be right, since GSR heads and blocks were actually being cast in 1993.
Old Feb 3, 2009 | 07:40 PM
vtecman's Avatar
any else have any opinions on this??
Old Oct 22, 2009 | 10:01 PM
xero_xero's Avatar
Have pics and a full explination.
B16 and Type-R motors have the same CAST head...some of the differences between the two heads are that the Type-R head has a better and stronger valvetrain, the cams, lighter valves, the better intake manifold and bigger throttlebody, and a mild port job from the factory.
b16 and type-r heads are stamped PR3-X (x being a random number...in this case its 4)
see:
P72 cast head - GSR b18c head
Also another random fact: u can tell the date of the head by the numbers to the far left of those circular stamps with numbers on it. See the " 0 0 " ? That means this head was manufactured in 2000.
Old Oct 25, 2009 | 10:45 AM
killacam661's Avatar
Also another random fact: u can tell the date of the head by the numbers to the far left of those circular stamps with numbers on it. See the " 0 0 " ? That means this head was manufactured in 2000.[/QUOTE]
where is the 00?
Old Oct 25, 2009 | 02:58 PM
xero_xero's Avatar
it is located on the pr3 head (b16) between the first two exhaust ports, the small circles have numbers on each side.
as far as the numbers on the p72 head, its located directly above the second exhaust port. which is a 98 upside down
Old Oct 25, 2009 | 03:06 PM
xero_xero's Avatar
Please take a pic, there is a possibility that it says 86, there was a head on the original b18 in 86 (japan only) but take a pic.
Old Oct 5, 2015 | 11:02 AM
Rodney Henke's Avatar
How about this one?Pc-1 hf-4
2220. This is from early 80a. I think a 1.5
Rodneyhenke@gmail.com
Old Oct 5, 2015 | 11:51 AM
tony_2018's Avatar
Fish Twig
OP needs to provide a picture of the head in question, straight up.
DirtyJeedai
May 14, 2015 02:58 PM
deadmonday08
Honda Civic (2001 - 2005)
Nov 12, 2010 04:02 AM
7rrivera7
Aug 4, 2006 09:25 AM
battlefield
Dec 24, 2002 09:46 AM
