JDM yellow fogs (ep3)
ok, so tommrrow i want to start putting in my foglights. it's doesnt seem to hard but i just got a new bumper and i dont want to cut the holes wrong. Is there a DIY anyone knows about to give me some pointer's to install them the cleanest way possible. Thanks
i hope you know the jdm fogs arent even yellow...... so its not jdm. Ebay right?
well here it is anyways diy.
http://k-series.com/tech_document.php?id=36
So they are real jdm foglights, where did u get them from and how much? I wanna get some new lenses. One more question, do you have the jdm/edm pre-facelift or facelift type r bumper? if you have the face lift bumper, the diy i gave wont work.
oooo. if they go on the usdm bumper, its not jdm. The real jdm foglenses come in ion crystal yellow and clear. i wanted to pick up some of those lenses
One quick question. I bought a pair of "JDM" yellow fog lights from ebay but according to an installation guide that I found online the main harness that came with the foglight kit doesn't match the one from the guide. My harness seems to have fewer plugs/connectors. Will this be a problem? Do I need an OEM harness?
If you have fogs with blue lens and use some yellow transparent film, will it change to a different color since the lens is blue instead of clear? I wanna change them to yellow but I'm thinking blue+yellow=GREEN
im not sure if it would change just watch out for the film. it may get burnt from how close the bulb is to the lenses. happened to mine so i am going to paint my lenses instead.
Yeah. I wanted some OEM USDM fogs (screw the yellow "JDM" stuff) but since my plate relocation is right in the way that solved my problem. NO FOGS. Haha. It's ok. The HIDs I have (6000K) are plenty bright and aimed just right so they don't blind other drivers.
