recharging civic a/c
Old Feb 3, 2009 | 11:51 AM
lilo_goki's Avatar
Default recharging civic a/c
i'm about to recharge my 94 civic si a/c, was just wondering if i have to add oil or is freon just fine. i'm also pulling a vacuum first, and then will be adding freon.
Old Feb 4, 2009 | 05:24 AM
↑↑↑↑Justin↑↑↑↑'s Avatar
Default Re: recharging civic a/c
i hope your not talking about putting oil in your a/c.
Old Feb 4, 2009 | 08:10 AM
instructor74's Avatar
There is a oil that is added to the system to lube the compressor that is specific to ac systems. To the op did you change any parts out like the dryer, compressor ect if so there are specs as to how muh oil to add to each. If not you should be okay to just evac the system and recharge it. There are other people on here that have a lot more exp on this then I do I am sure they will add more info. Just reread your post you have a 94 civic that system should be R134 and not R12 (freon) better make sure what system you have.
Old Feb 4, 2009 | 10:03 AM
98civdx's Avatar
Master Detailer
if you didnt change anything, you wont need to add anything but R134
Old Feb 10, 2009 | 01:59 PM
lilo_goki's Avatar
well i got the a/c lines from the junkyard, the receiver drier i bought it brand new, the compressor i got it from my cousin civic that he crash, so what do i have to do now, besides vacuum it?
Old Feb 10, 2009 | 08:26 PM
Well you will need to add oil to the system. If I remember the dryer gets oil also. If I where you I would change all O rings in the system since you are rebuilding it from multi parts. then vacuume things down the recharge the system
3rdmdqm
Honda CR-V & Element
Apr 25, 2018 09:21 AM
Vtec04
Honda Civic (2001 - 2005)
Jun 1, 2017 10:22 PM
angrysmileyface
Jul 31, 2014 04:53 PM
Nicefeet
Jul 10, 2012 09:45 AM
racer_X_123
Apr 12, 2007 07:33 AM
