Cast ebay turbo manifolds FLAME SUIT ON
Old Feb 3, 2009 | 09:31 AM
es_squared's Avatar
Default Cast ebay turbo manifolds FLAME SUIT ON
Yes I did a search, and a lot of people advised against the welded ones.. The manifold I have no wont give me enough clearance for the turbo because of the motor mount in the way but thats another story.. It may not flow as well as a real mani, but it looks beefy enough to not crack on my and **** up my turbo or anything else. input please.
Preferably wanting to hear from people that have used something like this.. although waste gate placement looks odd:
http://cgi.ebay.ca/92-01-HONDA-PRELU...|39:1|240:1318
Old Feb 3, 2009 | 09:34 AM
ProjectBB6's Avatar
Default Re: Cast ebay turbo manifolds FLAME SUIT ON
That is the worst type of manifold. Look at how its designed. Runners 1 and 4 hit 90 degree angles and the fire directly at each other. These kind of manifold design cause detonation. Best part about it is the waste gate placement. I also doubt that the manifold will crack. I recommend a Revhard cast manifold if you want to go that route.
Old Feb 3, 2009 | 09:37 AM
es_squared's Avatar
is there a contact for revhard on HT? their log mani looks like it would work
boosted ej8's Avatar
yea the runners are terrible but for an ebay manifold the waste gate placement isn't bad
most of them only have the waste gate over cylinders 1&2
Old Feb 3, 2009 | 09:47 AM
es_squared's Avatar
Also if anyone can suggest other decent log manifolds let me know
Old Feb 3, 2009 | 09:49 AM
TheShodan's Avatar
Moderator
you would have to go through Turbo-Kits.com in order to get the revhard manifolds. Miles Bautista is not on H-T.
Spoolin' performance makes good log manifolds and downpipe/dumptube combinations.
Old Feb 3, 2009 | 09:57 AM
es_squared's Avatar
Spooling performance had the log manifolds, but no package with dump/dp. However their mani looks a lot similar to the ebay one i posted up. STR log mani or something
Old Feb 3, 2009 | 10:24 AM
ProjectBB6's Avatar
I can sell you my revhard setup. I made 245whp @ 6psi on a 9:1 compression motor w/ recirculated dump. Should def make more on 10:1...
Here is a revhard cast manifold. Notice what they did in between runner 2 and 3. They dont allow 4 and 1 to fire directly at each other. Its pretty much the best that can be done with these small, cast, a/c compatible manifolds.
Old Feb 3, 2009 | 10:45 AM
es_squared's Avatar
Thats awesome dude, I'm also on 9:1 too so i dont doubt it'll make great power. sending you a pm
Old Feb 3, 2009 | 12:53 PM
B and B's Avatar
Loved
Community Favorite
The style I got for $100
Old Feb 3, 2009 | 05:43 PM
ProjectBB6's Avatar
He has a H22
Old Feb 3, 2009 | 06:52 PM
es_squared's Avatar
Originally Posted by ProjectBB6
He has a H22
word, probably should have clarified that .
Old Feb 3, 2009 | 07:24 PM
Adriano's Avatar
That is a copy of the drag manifold.
Adriano
Old Feb 3, 2009 | 08:23 PM
Boosted_B_Series's Avatar
We have used cheap cast copies at our shop, never any problems with cracking. Never really made any 'power' on any of em either.
Old Feb 3, 2009 | 08:39 PM
TehGhett0P1mp's Avatar
How did that end up working for you?
Old Feb 3, 2009 | 09:53 PM
blinx9900's Avatar
THANK GOD!!
OP do yourself a favor and get decent parts, if your going to get a cast manifold there are better options, meutek, inlinepro, even blox. The Spoolin logs are a nice option also for ~350whp or less goals.
Old Feb 4, 2009 | 01:19 PM
ashb82's Avatar
i an not trying to debate you but please tell how this will cause detonation.I am not saying your wrong i just want to know.
Old Feb 4, 2009 | 01:25 PM
blinx9900's Avatar
maybe he's thinking it can have like an EGR effect or something??? but yeah i don't think it would cause detonation... Cast manifolds have been used for YEARS on both FI and NA engines...
Old Feb 4, 2009 | 01:57 PM
ProjectBB6's Avatar
Because of the way its setup... it will cause a increased heat and back pressure. While tuning you will start to experience knock sooner than if you were using a tubular with runners pointing at a flange. Pm Tony1 about his knowledge on log manifolds. They work better on smaller motors, I believe due to the exhaust gas volume, but are bad on the 2.0+ motors. Here is a thread for some reference.
https://honda-tech.com/forums/forced-induction-16/looking-h22-turbo-log-manifold-dyno-numbers-manufacturer-2168460/
BTW, I know about your F22 build on Imports NC, looks good. I am Frompa on the boards btw...
Old Feb 4, 2009 | 02:00 PM
B and B's Avatar
Loved
Community Favorite
Haven't finished the build...
Old Feb 4, 2009 | 03:06 PM
es_squared's Avatar
Thanks for the input all, ProjectBB6 is nice enough to sell me his manifold though.
st3alth
May 16, 2005 06:07 AM
dcsportsciv
Oct 22, 2004 01:34 PM
Phat8186
Oct 5, 2004 07:42 AM
k20em2
May 20, 2004 05:10 PM
