Crx swap turning over but not starting
Old Feb 2, 2009 | 11:20 PM
Jdogg9107's Avatar
New User
Default Crx swap turning over but not starting
Hey so my car is not starting I have purchased new main relay and also new ignitor and spark plugs but yet doesn't still want to start I was getting spark than all the sudden it stopped I don't know what's the problem here it's my first swap so any info helps. does every sensor need to be hooked up as well? I'm almost tempted to take to an mechanic it's so frustrating
Old Feb 3, 2009 | 07:20 AM
mtber's Avatar
Default Re: Crx swap turning over but not starting
1. Get a factory helms manual for the vehicle.
2. Diagnose the igniton system per the manual's instructions.
Old Feb 9, 2009 | 12:24 PM
Jdogg9107's Avatar
New User
Sorry took so long to respond lack of computer access but where can i find this helms manual is it at library or do i have to get it from the dealer
Old Feb 9, 2009 | 10:24 PM
Romo Pyro's Avatar
Kragen has a Chiltons Manual, its like the same thing. But most people prefer Helms. Umm.. Just a thought, and Im only saying this because it happened to me when I was diagnosing an electrical problem I had. Check your underdash fuse box, Make sure all your fuses are good, because there's one that kills spark to your engine, so if you HAD spark and now you don't, you could have conceivably blown the fuse
Here is a diagram of a newer civic, because it's all I could find on Google, to show you which one I mean, Hope this helps.
Old Aug 15, 2009 | 05:37 PM
Jdogg9107's Avatar
New User
hey so it started up when i figured out few things but now its not starting again fuel pump starts getting spark i don't know what to check now any suggestions
Old Aug 15, 2009 | 06:20 PM
Top Ramen's Avatar
Default sometimes . . . .
random thing to check when your car mysteriously won't start --> the switch that the clutch depresses. The little rubber thing that pushes the switch in will get old, deteriorate and break off or flex too much to push the plunger. I have had a couple of situations where I was going nuts trying to find the issue and eventually worked back to that.
Old Sep 24, 2009 | 06:46 PM
Jdogg9107's Avatar
New User
Hey guys thanks for the help seemed that the ignitor died in the dizzy which I already replaced before but anyways it's running really rough like no power at all any ideas?!! V tec definately not hooked up but would that really matter at this point I would but I'm gonna have to wire a bunch of diff things to n from ecu n vtec solenoid
Old Oct 4, 2009 | 05:13 PM
PatPrimmer's Avatar
If you keep blowing igniters get a new set of leads. Make sure they are plugged onto the correct plugs. Do not crank the engine with the dissy wired in but a plug lead off.
gole
Honda CR-V & Element
Dec 22, 2014 04:56 PM
Ed ke6bnl
Jul 5, 2009 08:06 AM
Rob.
Mar 29, 2006 11:55 PM
CRXstress
Apr 16, 2005 08:39 PM
wizzards581
Mar 12, 2003 08:38 PM
