lowering springs question
i have an all stock suspension on my ef sedan, if i buy lowering springs with struts, what else do i need to make it all work? would i need to buy new shocks as well?
Shocks/Struts are pretty much the same thing.......so if your getting lowering springs and shocks/struts then you should be all set. But if you just wanna get new springs, then you will reuse your old stock shocks and struts.
um shocks are springs...... springs and struts are all you need but i would go with either coil overs or a small not too harsh 2.5" drop or something cause then it won't wear your tires too awful bad and it won't ride super crappy.....
Yes when lowering your car you should replace shocks as well because stock shocks can't handle with lowering springs well and eventually your OEM shocks will be blown. Do it right the first time so you don't have to do it twice. Best to buy a combo shock/springs.GL
Here is a thread I did when lowering my 4 door......used skunk2 springs with tokico blue shocks/struts and skunk LCAs also.
https://honda-tech.com/forums/showth...=tokico+skunk2
so if i get some Ksport GT lowering springs for EF that are on 170000 mile OEM EF sedan struts will i be okay? or what is a better suggestion. like just buy the springs and get new struts? i dunno
Get some new shocks also.......i dont recommend Tokico HPs though. If your gonna lower the car more than 2 inches that i would go with the Tokico Illuminas. My Tokico HPs already crapped out cause i lowered the car 2.5 inches and now it rides crappy again >=/
Yeah, I'd definatly get some new struts. We lowerd my car to just above legal and the stock ones blew in about a week. I've got the lowest ef sedan in town, but my exhaust is taking a beating, lol.
Anyway to answer the OP's question, you will buy new shocks, EF's do not have struts, they are different things. If you buy springs, you can either use your stock shocks and swap them (don't recommend that) or you can buy some new springs, and some shocks to compliment them.
Well you are the one that was right, I think your bf needs to learn more about cars before he starts spreading nonsense around. Does he call the "transaxle" a tranny or transmission too? Tell him he is WRONG.
crxaddikt
Sep 6, 2002 05:41 AM
