99 Prelude Turbo question
Hey everyone. First off I would like to say that I HAVE read a lot on the FI forum. That being said, I have a 99 base model with STOCK INTERNALS, and a turbonetics t3/t4 turbo on it. I bought it as a kit. It came with a cast exhaust manifold, which i heard was better than chrome pipes due to flow. I have a fairly big intercooler, and charge pipes, 880cc injectors, bigger fuel pump, MSD 6 digital ignition with boost retarded, the ECU was converted to OBD2, what ever one is programmable be it obd1 or obd2, And i have 3" exhaust from down pipe back. Now with all of that said, I have a few questions to ask all of you smart people... The exhaust side of my turbo, where you look at the turbine, I measured it and the diameter is 2 1/8". I have talked to a couple of people about a down pipe size. Some say 3" and some say your DP doesn't have to be bigger than the exit on the turbo. Well I have a 2 1/4" DP that runs down under the motor and just past the oil pan where it goes to the 3" exhaust. My question is that if this is restricting flow? And i heard someone say that DP size has alot to do with where your torque is on your RPM band. Im a little comfused. Should i scrap my 2.25" DP and go to 2.5 or 2.75?
the cast exhaust manifold KILLS power on h22's. way more than your downpipe is. i'd run atleast a 2.5 dp and a 3 inch if possible....but before you spend money redoing a downpipe, get a good exhaust manifold on there.
no, there is no need to ask you which manifold you are running because you already stated it is cast. i have built and tuned a TON of h22 cars, and each and every single one of them that have had a cast and/or log manifold on them have been down on power substantially compared to another similar set up with a tubular manifold.
Something like this?
http://www.synapseturbo.com/mm5/merc...kits_manifolds
Kind of pricey, I see some tubular ones on ebay, I know...
I'de get the Spoolin Performance manifold for the H-series. SPfab Quick4 -- $ 495.00
http://www.spoolinperformance.com/sp...ick4-p-59.html
http://www.spoolinperformance.com/images/minime1.jpg
prelude beast
Feb 15, 2004 04:44 PM
