Pipe size for stock H22 ports
Old Feb 2, 2009 | 06:45 PM
Quade's Avatar
Icon2 Pipe size for stock H22 ports
New to fabbing so forgive me for all the questions. It just that it's hard to get a manifold to suit my needs.
1. What size schedule 10 stainless steel pipe should I use to fab up a turbo manifold for my H22?
2. Can you flatten shedule 10 stainless steel pipe to take the shape of the H22 ports? If so what's the ideal pipe size to use ?
3. What will be the outside diameter of this pipe be? Does it depend on who makes it? I need to know so I can order one of these merge collectors from here -
http://www.burnsstainless.com/MergeC...ollectors.html
Reason for getting this collector? I like the fact that it goes into a perfect round to weld on a vband flange. anyone know the size of the inlet to the turbine on the Tial GT3076 vband turbocharger? I know the outlet is a 3" vband but they dont mention the size of the inlet.
Thanks in advance.
Old Feb 3, 2009 | 05:04 AM
Quade's Avatar
Default Re: Pipe size for stock H22 ports
bump
Old Feb 3, 2009 | 06:01 AM
spiceisler's Avatar
You can flatten the schedule 10 pipe in a vise. I'd say 1 1/2". I've used that before with no problems.
Old Feb 3, 2009 | 09:43 AM
boost_aholic97's Avatar
i have seen the 1 1/2 pipe flattened to fit. also that collector maybe a little harder to do your final welding on, you might want to look into a different collector, like one from agtronic or weirtech.
anton_
Feb 23, 2008 02:04 AM
meanEG
Welding / Fabrication
15
Sep 1, 2005 08:07 PM
ThaOnlyStunna03
14
Nov 18, 2004 03:38 PM
Roky
Jan 11, 2004 02:32 PM
rob d
Oct 27, 2002 04:41 PM
