D16Z6: Check my specs 75.5mm Vitara PTW/Ring Clearance?
Old Feb 2, 2009 | 02:06 PM
dez6's Avatar
Default D16Z6: Check my specs 75.5mm Vitara PTW/Ring Clearance?
I am building a d16z6 currently and I'm going to run 75.5mm Vitaras, my goal is 300hp. From the reading that I have done these are the specs that I plan on giving the machinist. Do these specs look ok for my goals? Any insight from Vitara users appreciated.
PTW
.0035 to .0040 for PTW clearance.
(Desired PTW) .0035 x 2 = .007
(75.5mm converted to Inch) 2.972" + .007 = 2.979"
Rings
Upper ring gap
006" x 2.927= 0.0178
Second ring gap
0065" x 2.972 = 0.0193
Old Feb 2, 2009 | 05:20 PM
thomas@LPS's Avatar
Default Re: D16Z6: Check my specs 75.5mm Vitara PTW/Ring Clearance?
PTW
Rings
Upper ring gap
Second ring gap
Ring gap seems about right. I would recommend a little tighter ptw clearance something around .0025 should be fine. Im running .003 with my forged wiseco pistons. Cast has a lower expansion rate than forged pistons. Just my .02 cents.
lilhatch89
Jul 27, 2014 04:59 PM
EG-SIXV-TEC
Aug 24, 2013 07:15 AM
swirve1
Feb 4, 2010 08:43 PM
sabremike21
Jan 3, 2009 11:55 AM
