about to
Old Feb 2, 2009 | 02:06 PM
nrst89's Avatar
Default about to
purchase a ef its a dx model...ac and everything...only second owner....clean title...clean body and interior...i dont to much for a ef but for 800 bucks i dont think i can pass it up...
now for a quick question:
i have a 2000 d16y8 that i want to swap into it but everyone telling me that its gonna be to hard wiring etc etc that i would be better off with a ls or b20? true? anyone want to trade a full ls or b20 swap for a complete d16y8
Old Feb 2, 2009 | 02:08 PM
93formula's Avatar
Default Re: about to
easy swap, bolts in, you will have to do a mpfi to dpfi conversion, obd0-obd1 jumper and a p28, then your set.
with the other b swaps you will need mounts, same amount of wiring but you will also need axles, shift linkage etc.
Old Feb 2, 2009 | 02:23 PM
nrst89's Avatar
so the d16 should be an easy swap? what about the 4speed gearbox?
Old Feb 2, 2009 | 02:35 PM
93formula's Avatar
the dx is 4 speed?? pick up a si trans from a 88-91 and it will bolt up to the y8
Old Feb 2, 2009 | 03:06 PM
CRX Toad's Avatar
Check out the FAQ lots of good info int here. It isn't that hard of a swap and has been done thousands of time. Try a google search too. You'll find info there too.
And since you made this a FS/FT/WTB thread it is locked.
SenseiRice
Apr 23, 2016 02:23 AM
mrEFman
10
Jan 20, 2007 06:01 PM
t-axiom1
Sep 18, 2005 08:35 PM
claydog
Mar 16, 2004 02:00 PM
EF9_R_Killa
Jul 8, 2002 12:10 PM
