"LSD" ...... are they any good ?
Old Aug 8, 2002 | 04:15 AM
eg6madness's Avatar
Default "LSD" ...... are they any good ?
Are the LSD shims that are made by Phantom Grip and AZ (the one the JDM honda Parts has) good ?
do they hold good ?
How has the best price on JDM LSDs ?
What is a good LSD that wouldn't hurt your pocket ?
Old Aug 8, 2002 | 04:45 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: "LSD" ...... are they any good ? (eg6madness)
PG and AZ are POS's
There was a Kaaz SOHC LSD on Ebay for $300.
Old Aug 8, 2002 | 04:50 AM
PSU-TEG's Avatar
Search, my friend, Search!! But here is a free-be....
In my opinion.... NO! Phantom Grips (and any other LSD that works under the same principal) are no good.
Here is one (of many) link that discuses Phantom Grips:
https://honda-tech.com/zerothread?id=156897
Oh, and there is no such thing as a "good LSD that won't hurt your pocket." You want a good LSD, your going to pay! If you want to go that route, I suggest you save up a little longer and get a good LSD... you'll thank yourself later!!
[Modified by PSU-TEG, 1:50 PM 8/8/2002]
[Modified by PSU-TEG, 1:51 PM 8/8/2002]
Old Aug 8, 2002 | 06:51 AM
TurbodCX's Avatar
Default Re: "LSD" ...... are they any good ? (Mista Bone)
hey mista where at on ebay, i searched and couldnt find anything..
brian
Old Aug 8, 2002 | 07:30 AM
AutoXsi2000's Avatar
I would do factory CTR or ITR possible for road race , quaife or kazz
Old Aug 8, 2002 | 09:22 AM
Kataku2K3's Avatar
Default Re: "LSD" ...... are they any good ? (mano77)
Yea Quaife or Kazz, I hate those Phantom Grip ones. But if you want one that is a little less expensive then just go with an OEM one.
Old Aug 8, 2002 | 11:55 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: "LSD" ...... are they any good ? (TurbodCX)
dunno, I was linked.
Old Aug 8, 2002 | 04:57 PM
.(Lazarus).'s Avatar
I've got a Phantom Grip in my EG, and they aren't *too* bad. My transmission happened to be out when the shop got its first shipment of PGs in. I got offered to have it put in for $100, so I said f'ck it, ok. First off it is NOT a real LSD, and whether you should put it in your car depends entirely on what you use it for. In a strait line, it feels just like a "true" LSD. When you pull into a turn, however, the difference is very clear. For about half a second, the car will push a bit. Not as bad as with an open diff, but there is a deffinate delay before the nose digs in. Obviously for auto-x this is a terrible, but for a pure street/strip car it isn't a bad mod to have.
The PG doesn't act like a solid diff either. The car's turning radius is exactly the same, and the front doesn't hop in tight turns like a 4x4 with locked diffs does. Also, the tires have not worn any faster than normal. I wouldn't bother using the thing for an SOHC since JDM options are so cheap, but for a DOHC where Type-R diffs are super expensive too, a PG might be worth it
Old Aug 8, 2002 | 05:13 PM
1 2 NV's Avatar
my kaaz broke after normal every day driving and about 3 trips to the track within 3 months. bought it brand new.
Old Aug 8, 2002 | 06:16 PM
shermanyang's Avatar
Default Re: "LSD" ...... are they any good ? (hondaatwsu)
I WANT AN LSD!!!
Old Aug 8, 2002 | 06:25 PM
frogsr's Avatar
quaife get from me. the difference is night and day with an open differential. if you're in the market for one anyways, spend the money for it--lifetime warranty too.
Old Aug 8, 2002 | 07:02 PM
1 2 NV's Avatar
Default Re: "LSD" ...... are they any good ? (frogsr)
i woudlnt say its night and day. id say its night and day in the corners. on the strip though i pulled just as good of 60fts with open as i did with LSD. granted this was NA not turboed.
Old Aug 8, 2002 | 09:43 PM
Big Teggie's Avatar
Anyone know if you notice a big difference goin from stock ITR to a Quaife LSD.
Old Aug 8, 2002 | 09:49 PM
lsvtec94's Avatar
how much do yuo want for a quaife?
Old Aug 9, 2002 | 07:00 AM
avividmemory's Avatar
Default Re: "LSD" ...... are they any good ? (JDMspecEG6)
Yea Quaife or Kazz
little pricy, i think quaife are slightly cheaper though
Old Aug 9, 2002 | 08:57 AM
acura_typer's Avatar
Banned
Default Re: "LSD" ...... are they any good ? (NoPowerAllRice)
I liked my Kaaz more than my Quaife.
Old Aug 10, 2002 | 12:54 AM
civic23g's Avatar
Default Re: "LSD" ...... are they any good ? (acura_typer)
From what I heard the phantom grips are junk,this said from a friend of mine with revhard powered GSR,he got rid of it and got a Kaaz I believe.
sh!ft
Transmission & Drivetrain
Jul 18, 2014 11:58 AM
Civic HX 121
Jul 2, 2012 09:06 AM
frostee
Oct 8, 2004 06:43 AM
MintyDip
Jun 6, 2002 02:05 PM
