crx fuel problem.
Old Feb 2, 2009 | 08:52 AM
98integralsB18's Avatar
Default crx fuel problem.
hey i have a problem with my crx. It has a B&M fuel pressure regulator and the needle is at 0. I was wondering if there is a fuel pump relay and im going to check and see if it is gettin power tonight after i get off work. but i just wanted to check and see if there was a relay before i threw in a new fuel pump. thanks
Old Feb 2, 2009 | 08:58 AM
xci_ed6's Avatar
Default Re: crx fuel problem.
yeah, the main relay. get a copy of the fsm and look at it.
Old Feb 2, 2009 | 12:06 PM
SeanWard's Avatar
I'm pretty sure the Fuel relay is mounted above the fuse box where you prp the hood. it's kind of a pain to get to. i've switched mine out twice before i realized the fuel pump was bad.
Old Feb 2, 2009 | 12:12 PM
93formula's Avatar
take a volt meter to make sure your getting power to the pump first.
Projekt CR-X
Sep 21, 2010 06:38 PM
usdmblackcivic
Sep 25, 2007 06:19 PM
CRX-Noob
Jun 17, 2006 12:21 AM
SLOW4drINTEG
Jul 30, 2003 07:09 AM
