temperature sensor messed up?
So after about 10 minutes of driving, my temperature needle shoots up to the red.
I do have fluid in the radiator, and also in the reservoir tank.
What I find weird is, shouldn't the temperature gauge only shoot up if the fluid in the radiator is hot?
I have my fan rigged up to run when I turn on my corner lights,
So even when I drive with my fan on, the needle still shoots up to the red.
What could my problem be? could it be because I have my fan hooked up to the corner lights? Instead, should I wire up the fan to its on switch and straight to the battery?
Could that maybe fix my problem?
I need your help H-T.
hmtcrxsir
Apr 29, 2009 06:48 PM
hardboiled egz
11
Jun 17, 2003 10:08 PM
