weird noise coming from engine????
Old Feb 2, 2009 | 07:03 AM
lovelove's Avatar
Default weird noise coming from engine????
yeah, i was wondering if anyone had a similar problem like mine. its coming from the engine near the belts and its not the belts that is screeching or loose. it sounds as if there is a blender in there. it sounds similar to a blender or more than a blender.
Old Feb 2, 2009 | 07:15 AM
j0keefe21's Avatar
Default Re: weird noise coming from engine????
hopefully its one of your accessories... that dosnt sound good at all
Old Feb 2, 2009 | 09:00 AM
96 EX's Avatar
Icon3 Re: weird noise coming from engine????
Doesnt sound good at all bro. I'd make sure its not the internals of your engine if I was you.
Old Feb 2, 2009 | 10:15 AM
8dxhatchy8's Avatar
maybe ur alternator took a ****!
Old Feb 2, 2009 | 11:42 AM
lovelove's Avatar
nahhh..........its still running.
Old Feb 2, 2009 | 12:20 PM
sorrule's Avatar
Is it a high screeching noise? If it is, replace all your accesories belts like P/S A/C alternator. They're probably worn and kinda loose now.
Old Feb 2, 2009 | 01:27 PM
slow_eg6's Avatar
does it speed up with higher revs!?
Old Feb 3, 2009 | 05:49 AM
lovelove's Avatar
its not the belts and it doesnt speed up with higher revs. im assuming maybe its the waterpump because it sounds like a blender. any other ideas???
Old Feb 3, 2009 | 06:47 AM
shizane's Avatar
Its probablly the tensioner on your timing belt. Mine was doing the same thing until yesterday when the belt finally slipped off. Yea stuck on the side of the road. I will tear it down thursday to inspect for damage. I would recommend fixing it now or it can be casatrophic to your engine if the belt breaks or comes off...I have been reading these forums for years even though I just have a commuter car. Good thing jdm replacements are only 750.00. This is my 2nd D15B in 5 years. 555000 what else could I ask for in a car...
Shane
1995 Honda Civic CX Hatchback
Old Feb 3, 2009 | 07:16 AM
lovelove's Avatar
yeah, thanks man.....ill look it up today before my timing belt snaps off or break and before my car is in need of a valve job.
Old Feb 3, 2009 | 07:44 AM
shizane's Avatar
Please post back with your findings. I plan to do the same.
Shane
Old Feb 3, 2009 | 04:14 PM
lovelove's Avatar
well, earlier today i did what you said and checked the timing belt. however, it wasn't the timing belt at all. so what im planning to do is to take all the belts off and start the engine to hear where the sound is coming from. if i still hear the noise, i plan to do trial and error, and put one belt on at a time to find where the noise is coming from. ill keep you updated in 3 days from now. Im too busy with school for right now but ill reply back on friday.
Old Feb 3, 2009 | 04:23 PM
j0keefe21's Avatar
good idea
Old Feb 3, 2009 | 06:19 PM
shizane's Avatar
lovelove, how did you check it? The reason I ask is because I checked mine by pulling off the grey cover on the right side of the valve cover and noticed the belt seemed fine with the normal slack prior to monday when it took a dump on me. I do believe the only way to check the tensioner is by removing the front wheel and pulling all the outers off the engine. Is this what you did? I sure hope its something else in your case, but I assure you in wasn't in mine. Keep us posted..
Shane
Old Feb 3, 2009 | 08:37 PM
Endo-land's Avatar
Take the valve cover off and check for anything out of place. I had this and an adjuster screw had come loose, was sitting in the top of my head. I replaced it and did a valve adjustment, it was like new.
Old Feb 4, 2009 | 07:10 AM
lovelove's Avatar
well, im not planning to take the front wheel off because i checked the timing belt and it seems like one side of the cam gear is tighter than the other side. dont know how to explain it but it is normal or fine. well, i dont really know for now but im guessing its the alternator thats making that sound. dang, it sounds like its whirring or sounds like a blender. i dont know yet but ill keep posting it up. im planning to check it out on friday. no time to check it out.
Old Feb 6, 2009 | 06:04 PM
lovelove's Avatar
hahaha....i finally...well sort of found the problem. i took out all the belts except the alternator and timing belt. turns out it wasnt the power steering belt. it was more like the ac belt. well, with the ac belt acting upon it, it turns out that maybe the bearing on the ac compressor or a pulley is rattling. but its not the belt. dont know much how to fix it but im gonna use the doctor's hearing thingy majig and find out later. later yall.
Old Feb 6, 2009 | 07:13 PM
Vindicator9000's Avatar
318 Curves, 11 miles
probably AC clutch or actuator then if the belt's good. I had one go out this year, and it made horrible noises. Wasn't particularly hard to fix, and I got a used clutch from the junkyard for $6. OEM is about $100 from Honda.
Old Feb 8, 2009 | 06:21 PM
shizane's Avatar
Well I found 12 teeth off the timing belt at the crank pulley. Put a new belt and water pump on and set up the timing. Car fired right up with no more blender noise. I lucked out and had no valve damage. Funny thing was that sound I had been hearing was the timing belt yelling replace me. I guess the slop from the belt was what was causing the sound. The tensioner was good as well. Already 500 more miles on it since Thursday. Good luck fixing your ride.
Shane
Old Feb 10, 2009 | 04:00 PM
lovelove's Avatar
i have found out the stupid problem which sounds like a blender and also made my belt squeaked like a mother****er. it was the pulley near the ac belt that helps drive it. took that **** off and replaced it and **** am i mad. gonna sell my civic. **** it and im gonna drive something more comfortable.
Old Feb 10, 2009 | 04:53 PM
joshkx's Avatar
lol, that what i hate when a little thing can cause so much confusion...lol
Old Feb 10, 2009 | 05:55 PM
Christopherian1982's Avatar
x2
Old Feb 10, 2009 | 06:38 PM
jdmboostedhatch's Avatar
does the car have ps? if you do the ps pump might not have any fluid and be making that noise, it happened to my friends car.
Old Feb 10, 2009 | 07:37 PM
93b20z's Avatar
well put a long extension or get a mechanic's stethoscope and test wheres you think its coming from... its easier to tell this way
Old Feb 11, 2009 | 02:32 PM
lovelove's Avatar
ummm...guys i already found out the problem. its the pulley that runs with the ac compressor and crankshaft. the bearing in the pulley went out.
JasonYo
26
Oct 29, 2022 11:44 AM
OSIRIuS23
Jan 18, 2013 05:26 AM
battosai
Mar 29, 2008 11:32 AM
farhan445
Nov 12, 2006 07:31 PM
redliner8000
Feb 19, 2004 08:49 PM
