Check engine light on
Old Feb 1, 2009 | 08:54 PM
B20-V-EG6's Avatar
Icon2 Check engine light on
I have 3 problems with my car!!
1 - 10 IAT - intake air temperature sensor
2 - 14 IAC (EACV) - idle air control valve
3 - 15 Ignition output signal
where are they located at?
people I need your HELP!!!!
Old Feb 1, 2009 | 09:01 PM
EgK2o09's Avatar
Default Re: Check engine light on
What model,motor???
Old Feb 1, 2009 | 09:22 PM
raidacaipo's Avatar
Iat is usually located on your manifold to the right side.. its a small plug with 2 pins.
IACV is usually located on manifold also.. its behind the manifold and it also looks like the IAT sensor with 2 pins.. its kinda near the tps
Ignition output signal?? Im not really sure what that means..
Old Feb 1, 2009 | 09:38 PM
93egSLEEPER's Avatar
im assuming you have a b20 like your name says? did you run a IAT sensor with the swap?
idle control is on the TB.. its a screw you can turn and adjust
Old Feb 1, 2009 | 09:43 PM
raidacaipo's Avatar
all B series manifolds run an IAT sensor..
hes not talking about idle control, hes talking about Idle air control valve aka IACV
EgK2o09
Dec 25, 2008 04:27 PM
kuks24
11
Aug 7, 2008 11:21 AM
Ri5e
Aug 14, 2002 03:02 PM
Ri5e
Aug 14, 2002 02:27 AM
Ri5e
Aug 13, 2002 06:31 PM
