Check engine light on
I have 3 problems with my car!!
1 - 10 IAT - intake air temperature sensor
2 - 14 IAC (EACV) - idle air control valve
3 - 15 Ignition output signal
where are they located at?
people I need your HELP!!!!
Re: Check engine light on
IACV is usually located on manifold also.. its behind the manifold and it also looks like the IAT sensor with 2 pins.. its kinda near the tps
Ignition output signal?? Im not really sure what that means..
idle control is on the TB.. its a screw you can turn and adjust
hes not talking about idle control, hes talking about Idle air control valve aka IACV
Ri5e
08-14-2002 03:02 PM
Ri5e
08-14-2002 02:27 AM
