help build a jdm d15b
aight i just picked this hatch up and it has some work done to it already .. its the fastest sohc that i have road in so far .. but i wanna build the motor now ... everything on is is in good condition and doesnt need replaced so im just gonna keep the parts that were already on the motor ... so help me out with any suggestions .. thanks
engine-
obd0 ls tb
94 d16z6 intake manifold
jdm d15b block
pm5 pistons
10mm spark plug wires
crane 251-0016 d16a6 camshaft (stage 3 or 4 not sure)
aem 3 bolt cam gear
intake
header
header back exhaust no cat or resonator [came this way] =(
aftermarket fuel rail
chipped ecu redline 9300 [6000k built in 2step]
tranny:
88 crx dx tranny
short shifter
stage 2 clutch
i think its a pretty good place to start with the mods already done .. but looking to fully build this ... but idk what to start at ... so where shoudl i go from here .. thanks
engine-
obd0 ls tb
jdm d15b block
pm5 pistons
aem 3 bolt cam gear
intake
header
tranny:
88 crx dx tranny
short shifter
stage 2 clutch
heres what you could do:
SEARCH!!!!! if you type d15b and search it you could probably spend the rest of your life before you read all the posts.
already searched it. but doesnt help me out. because the stuff thats done to my hatch already. so i wanted to figure out what would go good with the setup i already have..
i was thinking boost. but idk what all i would need to do that also so that it wouldnt blow or mess my head up or anything.
i wanna do a build and maybe boost later but just want help from others to see what sounds good. because idk where to start with those mods already done
umm.. not sure i can prob. check it tomm. i gotta go to my uncles shop and see when i can get a chance to paint my car and i'll see if he has the guages to check my compression ...
its probably close to stock compression ratio...
esentially a jdm d15b block with pm5 pistons (stock d15b2) and a z6 head is basically a d15b2 with a mini me swap
yeah but it has those cams, and with those you can tell a huge diff. from a stock mini-me swapped motor ... and i really do mean a huge diff. i'll get some better pics and maybe some videos of the car when i can. but im trying to find out some stuff that would be good to do so when i get my taxes back i can do the stuff
i'll go to the track whenever i get a chance ....i gott fix some problems with the car at the moment, get new brakes and front alignment, and some other minor things .... then i'll go ... it kept up no problem with my friends 00 SI on the way home from picking it up ... but we only went like 100tops .... but he didnt pull away .. so i mean you cant say it doesnt pull way/ run alot better than most basically stock sohc's
change the tranny to a zc and make a bigger differance than the SI plus add a light weight flywheel. if the compression isnt 190+ mill the head more and get a timing gear for it to really wake up that cam
i kinda fixed the exhuast by putting soem temporary hangers on my exhuast .. and when i did so for some reason i can feel the exhuast hitting my shifter and scraping on it ... i think its because my car has no cat ... i really do wanna swap a diff. tranny in it ... does the zc tranny bolt straight up to a 91 chassis and a jdm d15b motor
what do you mean by comp ratio? i thought you meant compression and was just abbreviating it ... sorry about that ... oh and how do i go about checking if i have a ccoolant leak ... i m pretty sure i have to because i refilled my coolant last night and this morning i had coolant on my driveway but didnt see where or feel where it came from ..... but wheh n i start the car theres a hose from the block to i think something that connects that hose to another and runs to the heater or something .. idk ... its on the back left side of the block and runs towards the firewall ... but like i was saying when i have the car running and all i can rub my finger where it connects and iwill have coolant on my hand .. but i dont understand why it wouldnt be there when the car isnt running and sits over night ... cause when i look under the car it looks like it drips from that exact place where the hose is ...
