oil leak
Old Feb 1, 2009 | 07:20 PM
gnccracer20's Avatar
Default oil leak
89 civic si leaking oil coming from the timing belt side of motor.. everytime i drive it and park it leaves a palmed sixe oil spot where i park it an its dripping off the timing belt side.. any ideas where it coming from????
Old Feb 1, 2009 | 08:28 PM
C_R_X_V_T_E_C's Avatar
Default Re: oil leak
wow dude, its either the oil pump or the main seal. take the f-ing cover off and look for yourself instead of sitting on your *** and having other people solve your problem. as a matter of fact, i would even fix it for you just to further prove my point.
get your hands dirty, powertard.
Old Feb 1, 2009 | 08:42 PM
90sedan's Avatar
Wow, way to be a useless jackass. So either the oil pump or the main seal is leaking? Are those the only options? And why would you suggest the oil pump, over say, the cam seal, valve cover gasket, oil pan gasket?
To the Op. There are a couple of things that could be the source of the oil leak. When looking at that side of the motor are you able to see any oil leaking out of the upper timing cover, basically the top half of the motor? If so its likely its the cam seal or valve cover gasket. If the top half looks clean then its likely it the crank seal(front main seal) or the Oil pan gasket. Its highly unlikely that the oil pump is leaking unless you had it replaced recently.
But since you said it leaves a ~3in wide puddle when parked its more than likely the cam or crank seal, that is unless you recently removed the valve cover (a pinched valve cover gasket will puke out oil). And an Oil pan gasket leak are generally slow and small.
Since you'll be in there replacing a leaking seal, you should plan on replacing the timing belt and water pump, especially if any oil got on the belt.
Old Feb 1, 2009 | 08:43 PM
bad day at the shop today.
Old Feb 1, 2009 | 09:09 PM
ef8sleeper's Avatar
LOL
that was the most unprovoked outbursts i have ever seen.
keep this guy away from kids and small pets.
Old Feb 1, 2009 | 09:10 PM
ef8sleeper's Avatar
i would look at the oil pan gasket and the crankshaft seal.
even the oil pressure switch on the back of the engine.
common issues for this area...
good luck....
Old Feb 2, 2009 | 03:10 AM
i do believe its coming from th3e top half cause the timing belt does have oil all on it and its a mess down in there..
note: i replaced the valve cover gasket... didnt solve a thing
Old Feb 2, 2009 | 08:42 AM
xci_ed6's Avatar
Originally Posted by ef8sleeper
LOL
I would not call it unprovoked, how the **** is anyone supposed to diag an oil leak from that description? Yeah, it's from the timing belt side....okay....take the ****ing cover off and look. None of us can do that from over the internet, and that is the only way to actually find out what the problem is. This thread is pointless.
Old Feb 2, 2009 | 04:39 PM
well bring your happy know it all *** down here and diagnose it.. i actually found the problem on here they told me it was the camshaft seal and thats wat it was u dumbfu** so yea i got my answer outta this thread go somewhere else an put ur usefull info in o yea its called hell dumbass!! an o yea i guarented ur the type of ******* that thinks ur **** dont stink and that ur ride is top dog of everyone elses an talks all tha **** on here an is all stuck up and a snobby little bitch that mommy and daddy paid for your car with.an i really dont give a damn wat u say in the reply to this everyone on here knows im right an *** watever else u say u kuntbag
Old Feb 3, 2009 | 06:38 AM
xci_ed6's Avatar
lol...not that it matters, but I paid for all my cars and bikes myself, and I've been an ASE master tech since I was 20 (averaged 96% on the 8 ASE tests). First in state for automotive diagnostics, 4th in the nation. Certified tech by Nissan, Toyota, and Honda, for diagnostics and hybrid systems.
What did you do to find the leak? Pull the cover off. What should you have done before you posted? Pull the cover off.
Old Feb 3, 2009 | 07:07 AM
Coltmorris's Avatar
wow..you are either slightly retarded, totally foreign, or 13 years old. Im thinking all 3
exactly
Old Feb 4, 2009 | 03:14 AM
haters!!
rush2112
Jan 17, 2008 03:55 PM
immalooser
May 17, 2006 03:27 PM
snatch
12
Mar 15, 2005 10:12 AM
Boostless97Lude
Jan 8, 2003 09:53 AM
