Need help! Driver door wont unlock properly
Old Feb 1, 2009 | 07:10 PM
M2B4's Avatar
Icon3 Need help! Driver door wont unlock properly
I posted about a week ago about how my drivers door wouldnt unlock properly. I assumed the actuator was the problem so i ordered a replacement. The new one moved freely and was working fine outside the car. I installed it today and connected all the rods. I tested it with the door open the power locks were working normal and everything was fine manually (when you lock and unlock you would hear a click). Once i closed the door i ran into the same problem as before. It would not unlock fully. you can hear the click when it locks but not when u go to unlock it. its like the rod needs to move another cm to unlock the lock. I undid all the rods and reclicked them in place just to make sure eveything was popped in right. the only way to unlock the door right now is to pop the rod that runs to the lock portion on the actuator and manually pull it firm while opening the door handle. anyone have any suggestions? im stumped on what it could be considering two different actuators have done the same problem. odd thing is it works 100% right with the door open, but as soon as it locks it wont unlock.
Old Feb 2, 2009 | 12:31 AM
slamdlude's Avatar
Default Re: Need help! Driver door wont unlock properly
Did you get a new latch or an actuator? The power door lock actuator has nothing to do with locking and unlocking the door with a key. You could also have a bent lock rod. The one that runs from the back of the door lock to the latch in particular. I have seen bent lock rods be the problem more than the latch itself.
Old Feb 2, 2009 | 04:39 PM
M2B4's Avatar
the actuator is what honda calls the whole thing. the hole assembly inside the door. the rod is pretty straight. im gunna tinker with it here ina sec. but its odd how it works perfeclty fine when the door is unlocked. it opens and closes fine.
kinda confusing but lemme word this right.
if the door is open i can move the interior luck/unlock key normally. it works perfectly fine. but if the door is closed it will not unlock. it does no slide far enuf to unlock the latch. make sence?
Old Feb 2, 2009 | 06:48 PM
M2B4's Avatar
ok after some tinkering this si what ive found out:
from inside the car if i pull on the door handle a few times while pushing the lock/unlock **** sometimes it will unlock and i can open the door. now keep in mind 2 differnt actuator/latches have done this so either both r bad which i doubt or its something else. its almost like the safety feature where u havta pull the door handle so u can lock the door has reversed on me?
another question,
with power locks does the passanger side lock have an extra sensor that will lock/unlock the car by turning the key from the exterior? with the new actuators/latch the passenger key will lock/unlock both doors, but the driver will only do the drivers do?
Old Feb 2, 2009 | 06:50 PM
Kronn 98SH's Avatar
Originally Posted by M2B4
another question,
I've never owned a 4th gen, but my 3rd gens were and my 5th gen is that exact same way.
Old Feb 2, 2009 | 07:38 PM
M2B4's Avatar
so off topic, but if you were to track down a jdm passenger side door lock u could have drivers side do both. might look for one. but any ideas on why the lock wont unlock everytime on my drivers door?
Old Feb 2, 2009 | 09:30 PM
M2B4's Avatar
what lube would be recommended to spray in there? wd40? white lithium grease? im thinkin about just spraying it down with lube and trying that.
Old Feb 3, 2009 | 10:38 PM
M2B4's Avatar
any ideas?
Red-Rag-B18
Acura TSX
Apr 30, 2013 09:12 AM
blacktibby07
Feb 5, 2011 06:37 AM
B20inDCinLBC
13
Apr 21, 2009 10:28 AM
zoolander
Mar 5, 2006 08:22 PM
