FS...complete ls/vtec,DA aluminum radiator,DA rear strut&lower tie bars
Old Feb 1, 2009 | 02:24 PM
hotrod0001's Avatar
Icon3 FS...complete ls/vtec,DA aluminum radiator,DA rear strut&lower tie bars
92-93 tails with brand new OEM gaskets--$50 plus shipping
SOLD!!!
LS/Vtec only 7000miles
B18A bottom, B16 head
rebuilt top to bottom
New honda bearings, seals and gaskets thoughout
LS rods with ARP rod bolts...PR-3 pistons
P72 oil pump
b16 water pump
Gates timing belt
OBD-1 GSR distributor with new cap and rotor, NGK wires and plugs
hondata intake gasket with extended intake studs
B16 intake manifold with LS throttle body
type-r valvesprings and retainers (b16 cams)
ARP headstuds
cometic headgasket(.045) 11.3to1 c/r
full-race LS/V kit (oil line, fittings and dowel pins)
Toda flywheel(resurfaced) with a comp stage 2 clutch(only 7000miles)
stock LS tranny (miles unknown, 2nd gear stratches if high revved)
Have most of the reciepts for the build
$1700 for everything!!!motor,tranny,Driveshaft shop stage 0 axles, innovative full motor mount kit and ecu PO6 (i believe) chipped with stock b16 map
Brand new 90-93 mishimoto radiator still sealed in the bag...also have 2 used 12" slim fans with brand new mishimoto mounting straps
SOLD!!!
PasswordJDM one piece rear strut bar (made for an EF modified to fit a DA)
SOLD!!!!
Benen rear lower one piece tie bar 90-93 integra
SOLD!!!!
Old Feb 3, 2009 | 02:58 PM
hotrod0001's Avatar
Default Re: FS...complete ls/vtec,DA aluminum radiator,DA rear strut&lower tie bars
BUMP!! New Price on the motor :D
Old Feb 4, 2009 | 08:23 PM
aznkr4zyboi's Avatar
How far are you located from oakland? pm me
Old Feb 4, 2009 | 09:22 PM
hotrod0001's Avatar
Originally Posted by aznkr4zyboi
how far are you located from oakland? Pm me
pm'd
Old Feb 5, 2009 | 08:36 PM
hotrod0001's Avatar
Icon3 Re: FS...complete ls/vtec,DA aluminum radiator,DA rear strut&lower tie bars
Bump
Old Feb 6, 2009 | 12:03 PM
hotrod0001's Avatar
Updated!!
Old Feb 7, 2009 | 12:09 AM
hotrod0001's Avatar
Bump!! come on people make me some offers!!! :D
Old Feb 7, 2009 | 09:51 AM
hotrod0001's Avatar
Bump!!new prices and updates.
Old Feb 17, 2009 | 09:05 PM
hotrod0001's Avatar
Bump
Old Feb 25, 2009 | 08:24 PM
OOOtony's Avatar
pm
KMk51188
Jun 11, 2006 05:46 AM
HYBRID FREAK
29
Apr 5, 2006 03:06 AM
untitled
Jul 13, 2003 08:41 AM
