Idle at 3-4000rpm.. WTF.. and no codes??? Please Help
Old Aug 7, 2002 | 10:03 PM
QWKPHKR's Avatar
Default Idle at 3-4000rpm.. WTF.. and no codes??? Please Help
(B16a1 in a 1990 CRX Si)
Hey guys, my idle is at around 3-4000 rpm and does not go down at all, even when it's warmed up. I changed 3 IAC's, tried 3 ecu's, ran new wires for the IAC, from the ECU and a power supply, checked all vacumm lines and I still have the same problem... Can someone please give me some ideas... I have no idea where I'm gettin this high idle from..
Thanx,
Pete
Old Aug 8, 2002 | 03:32 AM
QWKPHKR's Avatar
Default Re: Idle at 3-4000rpm.. WTF.. and no codes??? Please Help (QWKPHKR)
Another thing is that when I unplug the IAC my idle goes down to 1000rpm and then jumps to 2000rpm and then back and forth, and then when I plug it back in it shoots back up to 3-4000rpm... anyone with any ideas???
Old Aug 8, 2002 | 05:47 AM
Touch's Avatar
It couldn't of happened by itself, but I'd check the throttle cable. It might be too tight.
Old Aug 9, 2002 | 08:27 PM
dc2dragster's Avatar
From: eastside of the beach, westside of the coast, Long Beach, CA, usa
i had the same problem in my 94gsr, i was told it was my iac i couldn't get a new one so i just bought a jg tb block off the iac and now idles a 1000. u could try to change ur tb and see if thats the problem.
Old Aug 9, 2002 | 08:29 PM
salbaje's Avatar
check tps, and the idle adjustment screw on the tb
Old Aug 10, 2002 | 08:44 AM
Touch's Avatar
Default Re: Idle at 3-4000rpm.. WTF.. and no codes??? Please Help (salbaje)
let us know what it was if you got it.
Old Aug 11, 2002 | 08:33 AM
pg_thao's Avatar
check your tb gasket..
Old Aug 11, 2002 | 11:35 AM
quickspoolin's Avatar
[QUOTE]check tps, and the idle adjustment screw on the tb[/QUOTE
Ditto
jdm4drSi
Apr 6, 2007 08:19 AM
Midori Green
Jan 3, 2007 03:13 PM
4gen
Jan 11, 2004 05:28 PM
QWKPHKR
Aug 12, 2003 06:32 AM
QWKPHKR
Oct 8, 2002 06:37 PM
