CEL light flashed before the car is started.
I noticed today that when I turn the key to the number 2 spot,my check engine light does not come on for about 5 seconds and then shut off like it should. It stays on. It will stay on for about 45 seconds then it flashes 5 times and turns off.
I went to Advance thinking it was a pending CEL but it came back clear.
Is there anything that will cause this or is it trying to tell me something?
I just changed the cat/exhaust manifold and the upstream O2 sensor, I have no idea if this has any relation just thought I should throw it out there.
to add to what unevolved said, the image i attached is the check engine light, and the Maintenance Required light just says "Maint Req"
off topic: wtf, how do you post images in the thread?
To further add to what Ben850 provided:
The Maintenance Required Indicator can be reset.
Read this: https://honda-tech.com/forums/honda-civic-2001-2005-78/faq-how-reset-maintenence-required-light-1966027/ (link can also be found in the FAQ's)
Originally Posted by Ben850
off topic: How do you post images in the thread?
jfingers
Jan 12, 2005 05:45 AM
