my 95 civic still wont run?
Old Jan 31, 2009 | 01:10 PM
t1honda23's Avatar
Default my 95 civic still wont run?
my 1995 honda civic dx__i changed the dizzy to the original and has spark, but still wont run? im gettin fuel all the way through to the return line and in the fuel rail and have the firing order right, compression is good and have new plugs/wires and timeing s ok?
any ideas?
Old Jan 31, 2009 | 01:15 PM
dan617's Avatar
Default Re: my 95 civic still wont run?
did you check your fuses?
Old Jan 31, 2009 | 01:19 PM
Former User's Avatar
Is the CEL ON?
Is there battery voltage at the fuel injector connectors?
Is the spark bright white or bluish versus a weak orange color?
Did the timing belt skip a couple of teeth?
Old Jan 31, 2009 | 01:35 PM
t1honda23's Avatar
no the timing is fine, good spark (blue) i grounded a light to the block and stuck the postitive wire into the injector plug and didn't have anything but this light works to test fuses?????
t1honda23's Avatar
and the fuses ? dont have the fuse map so have no idea with one it would be
Old Jan 31, 2009 | 01:45 PM
Have you checked for CEL codes?
Use a voltmeter to test whether you measure 12V at the fuel injector connectors when key is turned to ON(II).
Old Jan 31, 2009 | 01:49 PM
t1honda23's Avatar
ok when i do that what do i do when there is not voltage?
Old Jan 31, 2009 | 01:51 PM
If the fuel injectors don't have power, then check hood fuse 31 and dash fuse 18. If they are fine, then the main relay might be bad.
Old Jan 31, 2009 | 01:57 PM
t1honda23's Avatar
ok but there should be constant power to inj. and if they dont work the car would do anything right, it would just crank?
Old Jan 31, 2009 | 02:01 PM
In short, yes.
Old Jan 31, 2009 | 02:03 PM
t1honda23's Avatar
could there be a relay or ?
Old Jan 31, 2009 | 02:15 PM
t1honda23's Avatar
is there any other possiblities cause car wanted to run @ one point but know nothing
Old Jan 31, 2009 | 02:16 PM
t1honda23's Avatar
but like i said that injctor should of turned on the light tester if worked right?
Old Jan 31, 2009 | 02:18 PM
jsant07's Avatar
Mechanic.
Old Jan 31, 2009 | 04:07 PM
yellow_eg's Avatar
U sure u didnt put the diz 180 degrees off?
Old Jan 31, 2009 | 04:36 PM
t1honda23's Avatar
i tried to but the dizzy wont seem to fit can it go in two ways?
Old Feb 1, 2009 | 06:06 PM
yellow_eg's Avatar
It wont fit unless u forced it in an put the bolts in, it dont take much to force it in though...
vdrive502
Apr 6, 2018 02:37 PM
lsvtec500
Sep 11, 2014 03:58 PM
///Mathew
Dec 28, 2013 06:12 PM
LM7_RX7
13
Dec 18, 2012 02:50 PM
red_crx_89
15
Aug 29, 2009 10:05 AM
