96-00 Civic lowering suspension. koni, ground controls, skunk2 INDY area
well since i traded my 99 civic and got a truck well i really want to lower the truck more than i do the 96dx civic....
a little use but i believe its still under 4K miles on the setup. only thing that you might want to buy is new springs for the front. they are 1inch short in front.... front springs are supposed to be for a 88-92 civic i believe is what they said. still work fine but if you lift them to max perch height its still pretty low. and if you want to drop the suspension lower than i had it set for daily driving a highly suggest also buying some ground control extended tophats!
Koni yellow struts all 4....
Ground Control coilovers for KONI sleeves, i also have 4 stock sleeves for it and 1 scratched up nut for it. the stock sleeves are good for a backup just incase you ever posibly switch or have a blown strut you can slap the springs onto the stock style struts.
so you get the 4 koni sleeves and 4 stock strut sleeves. and 5 thread nuts.
Spring rates for the standard so not to ruff. BUT if you do slam the car i would recommend some stiffer springs up front!
but the rears worked fine.
Skunk2 front TUNER series upper control camber arms.
Skunk2 rear camber arms.
lets say $800 bucks plus shipping or local pickup is great... Brownsburg, IN 46112
only thing you need to add is your top strut mounts and maybe the dust shields after you cut them down to fit.
i loved the suspension and planed to install it on my 96dx civic BUT i really want to lower my truck even more than i want the civic to be slammed right now. so if i can get 800bucks for everything ill let it go and eventually possibly buy the suspension new again.
if not solf for awhile i will possibly separate the camber kits. but i do not want to separate the konis and GC coilovers due to the fact the sleeves would be way to hard to separate from all the Orings holding them together! but i wont sell the camber kits before i sell the struts/GCs first.
LOCAL PICKUP ALWAYS PREFERRED BUT SHIPPING IS NO PROBLEM.
interested in the rear camber kit. I realize you are trying to sell everything as a set but if you change your mind and are willing to sell separately let me know...
Steven88italy
Suspension & Brakes
15
Apr 28, 2014 02:37 PM
Daniel_san
May 13, 2004 10:54 AM
