turn signal issue
Old Jan 31, 2009 | 06:17 AM
jhammond_82's Avatar
Reject Papi
Default turn signal issue
when i first got the hatch, the turn signals didn't work correctly. the corner lights didn't work at all. the relay kinda worked. it would click fast one way, and normal the other way. usually when it clicks fast, it means you have a blown bulb. i replaced all the bulbs and replaced the relay yesterday. the corner lights work now, but it still flashes fast when i turn left, and normal when i turn right. what else is there to look at? i looked at the wiring, and everything is in tact and grounded like it should be. (i used a test light and lead wire). all the lights work, but its annoying to listen to it, lol. any suggestions?
Old Jan 31, 2009 | 07:10 AM
apekd's Avatar
Default Re: turn signal issue
short to ground, bumper bulb may be dead, bu t check wiring, take a DMM and check for continuity from the power for the turn signals to the body ground. if there is, then you got a short.
Old Jan 31, 2009 | 08:11 AM
93formula's Avatar
the fast flashing can also mean one of the bulbs is on its way out, so it may be one that works that you havent changed yet.
hybridnorth
37
Feb 16, 2019 06:13 AM
HondaAccord333
Feb 19, 2018 08:04 AM
gtcali
Sep 23, 2005 02:24 PM
eg8000rpm
Apr 27, 2005 12:37 PM
