Fuel cutoff switch w/ relay diagram.
Old Jan 30, 2009 | 09:36 PM
Ldo's Avatar
Ldo
Icon2 Fuel cutoff switch w/ relay diagram.
So do we connect 87 to 86 as shown or 87 to 85? I've read conflicting info from different write ups.
Thanks.
Old Jan 30, 2009 | 10:02 PM
traxxasx's Avatar
Default Re: Fuel cutoff switch w/ relay diagram.
skip all that.
cut the yello wire at pump. add 1 wire to each end, run them to the switch/connect to switch. now your done, flip switch to make connection, flip it other way to break connection. lol thats how i do it, wrap wires in stock wire loom along driver door.
Old Jan 30, 2009 | 10:07 PM
Ldo's Avatar
Ldo
Originally Posted by traxxasx
skip all that.
Nah, I want to run the switch a little further away from the cut point. That's why I need a relay to not lose fuel pressure.
Old Jan 30, 2009 | 10:31 PM
Clipsed's Avatar
85-fused constant 12v+
86-ground via switch
30-relay side of wire
87-fuel pump side of wire
the way you have it will not work at all, you would need to do 30 to 85. Also, it only matters if 85 or 86 get power when it is diode isolated, other than that, either can be power of ground. If you do 30 and 85 together, you will draw more amps to power the relay, thus possibly ****ing something up, OR your fuel pump not getting the power it is asking for.
Old Jan 31, 2009 | 04:04 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
I was about to say good job, but can we get this resolved so we KNOW that this is the best way?
I want to use a relay too, long wire friendly, etc
Old Jan 31, 2009 | 03:59 PM
Ldo's Avatar
Ldo
Now I'm even more lost than before.
Old Jan 31, 2009 | 04:21 PM
Clipsed's Avatar
wow... seriously... If you don't know what a diode is, how a relay works, and ohms law... then you should NOT be doing ANY wiring on your own car...
The way I posted for you on how to wire up your relay is the best and safest way. I've been doing wiring for over 6 years now. But I wouldn't take my word for it. Why not read up yourself on what a relay is and how it works, read why in SOME cases it DOES and DOES NOT matter if pin 85 and 86 get power or ground, and what ohms law is. Do you even know what a multimeter is and how to use one? Not bashing, just a serious question. Wiring is not something to mess with if you really don't know your stuff as you can cause a fire.
But yea, buy some mobile electronics 101 books, read up on your ****, don't take my word for it if you don't believe me.
Old Jan 31, 2009 | 04:34 PM
Clipsed's Avatar
Here I drew up a pic to make it easier for those that don't understand words of what I was explaining. . .
Old Jan 31, 2009 | 08:51 PM
Ldo's Avatar
Ldo
Thanks for the diagram and the thorough explanation. As for you bashing, not at all. I have thick skin. Trust me, I'm not going to mess with anything in my car until I know for sure what to do. Everyone has to start somewhere, and this is my somewhere.
Old Feb 2, 2009 | 09:22 AM
Clipsed's Avatar
cool, glad you didn't take it offensively, because I know lots of people take my posts so.
Old Feb 24, 2009 | 05:15 PM
This is different than the image you post... ?
Also, where is a good place to get the power from for the relay? and how many amp fuse?
*neat
http://www.mp3car.com/vbulletin/faq-...w-wire-up.html
thecruzs2007@yahoo.com
Jan 2, 2010 07:11 PM
beastman@
Audio / Security / Video
May 17, 2008 01:05 AM
96electronH
Dec 2, 2007 05:29 PM
99fbpem1
Aug 19, 2007 04:23 PM
Simple
13
Jan 10, 2004 07:57 AM
