4" Downpipes and Clutch slave bleeder screw ideas....
Old Jan 30, 2009 | 07:05 PM
wade's Avatar
Default 4" Downpipes and Clutch slave bleeder screw ideas....
It is a close fit for a 4" DP between the rad, manifold and clutch bleeder screw. Does anyone make an aftermarket slave cyl. with a better positioned bleeder?
Is it possible to weld closed the bleeder hole, and Re-Tap the same pitch thread more on the frontwards side of the slave?
Old Jan 30, 2009 | 07:23 PM
mrbsponge's Avatar
Default Re: 4" Downpipes and Clutch slave bleeder screw ideas....
i wondered the same thing on the bleeder welding, i just dented mine in with a hammer and dolly, mines aluminum tho.
i was wondering if you could put a line to just move it to a different area and the bleeded or the end of the line maybe a few inches away
Old Jan 30, 2009 | 07:32 PM
PSI2HI's Avatar
Former Vendor
We run our 4" DP's past the bleeder to the pass side then bring it back under the pan, offers a lot more clearance.
Idk if this pic helps or not but you can kinda see the bleeder nipple for refrence:
Old Jan 30, 2009 | 09:34 PM
AdamB18C1EK's Avatar
mine is beat in with a hammer lol and i grinded some off the bleeder
Old Jan 31, 2009 | 02:08 AM
DaveF's Avatar
for some reason i think the prelude slave cyl. has the bleeder facing 90 degrees out the end, going upwards. but i could be wrong. i know its differant though.
EDIT : i was wrong, it faces foward..
Old Jan 31, 2009 | 03:53 AM
wade's Avatar
can a prelude one be used on b series?
Old Jan 31, 2009 | 04:10 AM
DaveF's Avatar
im pretty sure. lol. i didnt come up with that idea on my own, ive seen in on here before, but not sure where or when. it was a few years ago.
Old Jan 31, 2009 | 07:58 AM
b20beast83's Avatar
yes ive done it b4
Old Jan 31, 2009 | 08:21 AM
RedRCKT000's Avatar
I had to shave mine to make it fit with the 4" downpipe
Old Jan 31, 2009 | 08:49 AM
Bailhatch's Avatar
I just cut the nipple off mine. I never use a hose on it anyway. Bleed into pan, hose DP and bell housing with brake clean, done.
Old Jan 31, 2009 | 11:45 AM
Turbocivic94's Avatar
I been using prelude slave cylinder for about 4 years now. You have to longate one of the holes to make it fit. works great
Old Jan 31, 2009 | 02:30 PM
Bailhatch's Avatar
whatever man. I'm not switching until I hear of someone using it for at least 5 year.
Old Jan 31, 2009 | 08:08 PM
LastGenEK's Avatar
hahahahahahahahaha^
Old Feb 1, 2009 | 05:54 AM
non-VTEC's Avatar
what year prelude slave cylinder?
Old Feb 1, 2009 | 06:56 AM
DaveF's Avatar
whatever years came with hydro trans ? i would imagine 92 up to ... whenever ?
Old Feb 1, 2009 | 11:04 AM
905_Legend's Avatar
Has anyone had any issues with the heat that close to the slave or no, I'm in the same boat. You guys just switching them for the ease of bleeding.
Old Feb 1, 2009 | 02:18 PM
92-96 prelude
Old Feb 1, 2009 | 03:27 PM
Turbo92cx's Avatar
Thought Retracted!
Old Feb 1, 2009 | 07:26 PM
rota92
Guest
Posts: n/a
I used a prelude on my D2B setup without any issues as I to had clearance issues.
Old Feb 1, 2009 | 11:09 PM
rip94delsol's Avatar
why not put a SS braided line with a bleeder screw on the end?
Thats what Tilton does with their throw out bearings. I will get a pic of mine up tomorrow!
Old Feb 17, 2009 | 12:22 PM
SPOOLINmatt's Avatar
sorry but has anyone used the prelude slave cylinder with a scatter shield?
Old Feb 17, 2009 | 12:50 PM
Bailhatch's Avatar
Even stock hydro throwout bearings have that...I don't see how adding fittings and a line would end up being any smaller than a stock bleeder though
Another option would be to use a pull type slave mounted on the front of the transmission. I am thinking of trying this as I'm pretty sure I have cooked mine in the last couple years. It takes in air very slowly so I need to rebleed it every 6 months.
Old Feb 17, 2009 | 06:38 PM
seen4ever's Avatar
i just cut off my bleeder screw and put a mild bend into the dp, consideirng my downpipe is sch40, i doubt it really did much.
Old Feb 18, 2009 | 02:04 AM
wade's Avatar
sch40 Dp??? what are you on, lol.
Manifold material is what sch 40 is made of and sch 10.
You sure you didnt mean to say your downpipe was 14 or 16ga?
A 4" schd. 40 downpipe would weigh over 100lbs.
Old Feb 18, 2009 | 04:33 AM
LOL not to mention how much sch40 bends and pieces are for that.
Indestructible.
