Suspension & Brakes Theory, alignment, spring rates....
Need Help with Rear Camber
Old Jan 30, 2009 | 10:19 AM
EJ6JON's Avatar
Default Need Help with Rear Camber
Ok so im new to this camber method haha. Well I have positive camber in the rear and cant slam my car since it rubs. Im wondering if theres anyway I can fix it without buying a aftermarket camber kit. Well lmk thanks If theres a thread like this and answers on it plz lmk as well
Old Jan 30, 2009 | 10:51 AM
Tyson's Avatar
Default Re: Need Help with Rear Camber
how do you possibly have positive camber in the rear?
hit any curbs?
use any aftermarket lower control arms?
Old Jan 30, 2009 | 11:04 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If this is the 98 Civic listed in the OP's sig, and he's using aftermarket (or stock) 92-95 Civic LCA's, then yeah that'll make for some nasty positive camber.
Old Jan 30, 2009 | 11:13 AM
Tyson's Avatar
i dont think theyre even compatible.
Old Feb 2, 2009 | 11:16 AM
EJ6JON's Avatar
hit any curbs?
No , I was informed by Previous owner of the LCA Skunk 2 it had so im guessing that may be it
lol nah man wont work
What he said
I'll try to snap a few pics but its raining , So my guess is I'll have to buy Aftermarket LCA Right or wrong ?
Old Feb 2, 2009 | 12:02 PM
Community Builder
You need to figure out why you have positive camber in the first place. A car shouldn't ever have positive camber, even on stock suspension.
Old Feb 2, 2009 | 12:25 PM
Tyson's Avatar
so you have aftermarket LCA?
if its not Skunk2, but SPC instead, then that would explain the positive camber as they are purposely set in. which is why i never recommend that brand specifically.
Old Feb 3, 2009 | 07:41 AM
EJ6JON's Avatar
The car before had aftermarket lower control arms Skunk 2 from what the previous owner stated n he put stock ones and bam positive camber problem
Old Feb 3, 2009 | 10:58 AM
Community Builder
They must have been the incorrect arms, or you have the incorrect arms on there now. Going from aftermarket back to stock LCA's shouldn't change camber at all if they were the correct application for both the stock and aftermarket parts.
The only way the camber could be positive after switching LCA's is if the current LCA's are shorter than the ones that were on there previously.
Old Feb 7, 2009 | 06:52 AM
EJ6JON's Avatar
Yea I think this maybe it
Old Feb 7, 2009 | 07:30 PM
EJ6JON's Avatar
dont kno but maybe u can see the rear alil here
Old Feb 7, 2009 | 07:32 PM
EJ6JON's Avatar
Old Feb 7, 2009 | 11:36 PM
xd69's Avatar
Maybe the previous owner did the camber trick. Where you add washers to the rear UCA to loose excessive negative camber. Check if there is any washers or anything fishy with the rear UCA
Old Feb 8, 2009 | 05:37 AM
Community Builder
Either the upper arm is pushed out (washer trick like mentioned above) or you're using the incorrect lower arms (shorter than the stock 96-00 arms).
If none of the above, then something has to be bent/damaged, although I don't see that happening equally on both sides. Take some pics of the control arms underneath the rear of the car if you can.
taquatch.
Suspension & Brakes
Feb 4, 2009 11:39 AM
EJK20R
Suspension & Brakes
Mar 19, 2006 10:26 PM
3R1C
Oct 27, 2003 04:21 PM
bartek_b
Oct 7, 2003 04:45 PM
