4" exhaust anyone?
Old Jan 30, 2009 | 09:43 AM
spoolinlude's Avatar
I live under a rock
Default 4" exhaust anyone?
Yeah that's right I said 4" exhaust. Has anyone ever seen one on a 4th gen? It's probably overkill for my gt35r setup, but i just put my ESP traction bars in and I got to thinking that "I could probably fit a 4" if I wanted to" lol. I don't necessarily plan on doing this being that I have all the material for a 3", but I was just curious if anyone had ever seen one on a 4th gen..... because I sure haven't.
Old Jan 30, 2009 | 11:14 AM
oranginal's Avatar
Default Re: 4" exhaust anyone?
i would think a 4" pipe would scrape, especially right under the oil pan.
i have seen pics of it done one one prelude, so i can say yes it has been done.
what are people doing about 3" downpipes/flex pipe clearance? right below the oil pan. too low. would a moroso pan save any room, even and inch would be nice.
Old Jan 30, 2009 | 12:08 PM
1992MitsudaPrelipse's Avatar
my friend has 4.5, so it can be done, may have to modify to fit kind of crap though.
Old Jan 30, 2009 | 02:17 PM
Prudz_lude's Avatar
isn't md or oaks running a 4" exhaust?
Old Jan 30, 2009 | 02:19 PM
ALLxMOTOR EG's Avatar
Vietnamese!
2 inch would be enough.
Old Jan 30, 2009 | 02:24 PM
HiPsi's Avatar
How?
Old Jan 30, 2009 | 03:22 PM
Hawkze_2.3's Avatar
2" is definitely not enough for a GT35R... 4" would be tough. Getting under the oil pan and then under the rear control arm would probably be the tightest spots.
Old Jan 30, 2009 | 05:00 PM
93prelude615's Avatar
i think gregbb1 was running a 4 inch setup...
it can be done..
but if you are going to be driving it on the street much... stick with 3.
Old Jan 30, 2009 | 05:04 PM
Vietnamese!
oh my bad i didn't realize it was a GT35R, i misread it. haha
Old Jan 30, 2009 | 05:07 PM
snobordboy's Avatar
Moderator
GregBB1 did have a full 4 inch aluminum exhaust on his car, granted he was making 640 whp and drove it on the street alot. The flex section was a bit rubbed up, but it worked for sure. The exhaust would still be cool to the touch at the tailpipe after repeated hard runs!
If you are really pushing a GT35R, it could use the breathing for sure, just don't expect to have the lowest car in town.
Old Jan 30, 2009 | 05:17 PM
MLBZ521's Avatar
What would 2" be good for period is what I want to know??
Mostly stock H22s with 3" exhaust have had proven gains.
So I don't know what 2" is going to help at all..
Old Jan 30, 2009 | 08:09 PM
streetracer6rpt's Avatar
I got a 4in DP on my 5th gen.... Pictures on link
Old Jan 31, 2009 | 11:09 AM
jlude90's Avatar
why would a cool tailpipe be of any benefit?
Old Feb 2, 2009 | 06:36 AM
I live under a rock
Well, I haven't heard from md23 yet, I'm curious as to what he's running.....
I agree, the tighest spot would be the rear control arm area.... I have the moroso pan, I think it will fit through that area ok.... The other part I'm worried about is right off the turbo. I specifically bought the ESP traction bars to allow for more room for a bigger DP, but now that they're installed, the crossbar is basically in the worst spot it could be, directly below where the DP should run. If I trim the tabs for the "front mount" off the cross bar because I'll never use them, I think I can get it through. I also was thinking of using a 135 degree bend directly off the turbo, but I can't be sure that will work without actually doing it, and I don't want to blow 80 bucks on the bend just yet. I know a "pipe-cut" DP would snake its way in there just fine, but I'm not about to drop a G on an exhaust.... unless it really comes to it. Worst case, I already have everything I need for a 3", I'll just run that.
If anyone can find pictures of a 4" on a 4th gen, I'd love to see them, I can't find anything as of now......
Old Feb 2, 2009 | 08:08 AM
ImPuLsIvE's Avatar
4" is pure overkill. 3" IMO is the biggest you can go without asking for trouble. If you're that worried about back pressure, get a 3" exhaust from the turbo-back and get an electronic exhaust cut-out and install it before the cat on the DP.
Seriously.. I can barely drive my car with my 3" DP as it is.. 4" from the oilpan back is just stupid.
Old Feb 2, 2009 | 08:52 AM
I live under a rock
Well, its only overkill if you're running a really small turbo.... ask any of the SFWD drive guys they all run 4" on a "street car". Hell, some of the large turbos come with a FIVE INCH v-band now! The only trouble I see in running a 4" is the clearance issues, and the cost cuz I'm a cheap SOB. I don't run my car 1/2" off the ground, but also don't like thinking about my exhaust hanging down lower than any part of my car, if I were to do this, I'd make up some sort of skid plate to at least take some of the impact if I hit sometime. Like I said, I haven't made up my mind, I just got to thinking about it and wanted to see if anyone had done it yet....
Old Feb 2, 2009 | 10:21 AM
hyabusa hunter's Avatar
here is mine, 4" straight of the turbo, i have a fullrace ramhorn with a SC61 (soone to be BWS366)
Old Feb 2, 2009 | 12:42 PM
md23vtec's Avatar
check your pm
Old Feb 2, 2009 | 11:17 PM
Peeonu25's Avatar
its turbo... open downpipe FTW
Old Feb 3, 2009 | 03:52 AM
I live under a rock
busa hunter, I can't tell from that picture, but are you using some kind of home-made traction bar? If so, it looks like your cross bar is much farther forward than mine, and also that your turbo may hang a bit farther away from the block than mine (i'll post a pic tonight so you see what I mean) I am glad to see how it looks though! Nice job!
If my cross bar wasn't it the location that its in, I would be just fine, its just going to be tricky to get around.... my plan was to tack it together myself and have it finish welded by a professional. But getting the DP through that area might be more than I can chew....
mohater
Jul 30, 2013 01:09 PM
codye3m
Oct 28, 2008 08:55 AM
Fully_Built
Feb 6, 2008 09:21 AM
h22sedan
Jan 8, 2007 05:34 AM
