Where To Find Mud Guards 94-97 Accord EX
Old Jan 30, 2009 | 08:58 AM
BBallz24's Avatar
Default Where To Find Mud Guards 94-97 Accord EX
Where can I find parts 29 and 30? Don't want to spend $80/per.
These are the part numbers
43254-SV1-951
43253-SV1-951
Old Jan 30, 2009 | 09:03 AM
P_Adams's Avatar
Default Re: Where To Find Mud Guards 94-97 Accord EX
43254-SV1-951
43253-SV1-951
Honda Genuine Parts (OEM) or a Salvage Yard. They are "Dealer Only" items and only available new thru Honda Parts Division.
Where do you get $80.00 each?
$23.00 each from Majestic Honda, Lincoln RI
http://www.hondaautomotiveparts.com/...9+%28NISSIN%29
You won't find them cheaper.
There isn't enough demand for an aftermarket sourse.
P
Old Jan 30, 2009 | 11:19 AM
BBallz24's Avatar
This is where I got it. Looks to be the same, but different part numbers.
Majestic Honda
Old Jan 30, 2009 | 03:35 PM
VTECn83's Avatar
http://www.tasauto.com/Product/Browse.aspx?d=313&p=1
Try this.
Old Jan 30, 2009 | 03:54 PM
P_Adams's Avatar
Majestic Honda
Majestic uses their own numbering system, but it's the same unit.
Ok, try this... Saccucci Honda. Middletown, RI
http://www.hondapartsdeals.com/hpa_parts_list.php?vin=&Label%5BProductID%5D=ACCOR D&Label%5BYearID%5D=1996&Label%5BDoorID%5D=4&Label %5BGradeID%5D=EX&Label%5BAreaID%5D=KA&Label%5BTran smissionID%5D=4AT&Label%5BSectionID%5D=CHASSIS&Lab el%5BIllustrationGroupID%5D=REAR+BRAKE+%281%29&Pro ductID=5&YearID=14&DoorID=4&GradeID=8&AreaID=2&Tra nsmissionID=5&SectionID=6&IllustrationGroupID=8225
$23.00 each Pn# 43253-SM4-953 / 43254-SM4-953
P
Old Jan 31, 2009 | 09:37 AM
BBallz24's Avatar
OK, I guess they just have different numbers for each year. They look the same. Are the required for the brakes? Will it keep the calipers clean from dirt and such? I'll be able to get a pair for that price. They all look the same, just different part numbers.
Old Jan 31, 2009 | 11:04 AM
Zerophase's Avatar
Ever think about trying the junkyard.You could probably get them for about $10 at the most.
Old Jan 31, 2009 | 11:34 AM
P_Adams's Avatar
I would suggest asking what the difference is between the 1996 EX RR Disc Shield and the 1997 EX RR Disc Shield.
They are different PN#'s and decidedly more expensive for the '97.
I have no rational explanation for this. They are a none structual item (to which nothing is attached) but are functional. I see no reasoning why they wouldn't be interchangable.
I apologize for the confusion but you weren't specific on the year....
I looked up the '96 version.
Your best bet is a salvage yard (A "You Pick It" if you're up to it) or someone local that's parting out a 1997 EX. You won't find something like this on EBay or Craig's List unless its included with a rear brake upgrade package.
They not only keep debris from fouling the rotors/pads, but also direct air flow around the rotors, helping them disipate heat.
P
RickJoyce
Jun 2, 2019 12:44 PM
EvrenTR
Honda Civic (2006 - 2015)
Jan 19, 2016 11:41 PM
dleccord
Jan 17, 2009 05:36 AM
AWD: Jeff
Jul 13, 2002 05:16 PM
