Humming Noise in 1990 Accord?
Old 01-31-2009, 11:00 AM
jttrct4's Avatar
Default Humming Noise in 1990 Accord?
I tried to start my car today in my '90 Accord. I turned the key and it made this humming noise, only when the key is turned. I tried to start the car and it turned over once then it just shut back off. So I tried it again around an hour and a half later, the humming noise is still going only when the key is turned but now the car starts and works fine. I think the humming noise sounds like it is coming from underneath the dashboard maybe. I am going to take it to Advance Auto Parts to get an Electrical Test done to see if it's the battery, alternator, or starter but do you think it could be anything else? I had troubles before with the "Sport mode" light being on and the car wouldn't run as good but had it fixed and the light, I believe still stays on but it has worked fine. What could be the problem with my old car? lol
Old 01-31-2009, 12:05 PM
P_Adams's Avatar
Default Re: Humming Noise in 1990 Accord?
Other than the normal "uncalled for" answer to anything involving "Humming" , I'm at a bit of a loss.
If this is located on the right/center area of the dashboard, you may have a issue developing with the Heater Blower Motor.
Relays (and even the Directional Flasher) can make 'buzzing' noises.
If you can be a litle more difinitive, maybe we can pin this down for you.
P
gavingt
06-22-2017 09:28 PM
gosaha95
Honda Civic (2001 - 2005)
07-20-2015 08:40 PM
jinxie
01-22-2011 07:39 AM
Quick Reply: Humming Noise in 1990 Accord?
