I need some swap help b18c-hatch deal
Old Aug 7, 2002 | 07:15 PM
HybridHatchC1's Avatar
Default I need some swap help b18c-hatch deal
I just recently purchased a 01 b18c and i was wondering if i had to get a new ecu,dis,altinator, or will the OBD2 just plug in?
So basicly what i am saying is what do i need to do to put a 01 b18c into my 92 dxhatch
Old Aug 7, 2002 | 07:46 PM
Default Re: I need some swap help b18c-hatch deal (Civ-JDM)
help i want to get this installed!!!!!!
Old Aug 7, 2002 | 08:26 PM
drvfast's Avatar
u will need Engine, intake manifold, fuel rail w/ injectors, throttle body, throttle cable, exhaust manifold, alternator, distributor, ECU, transmission, starter, clutch, pressure plate, flywheel, axles, intermediate shaft, shift linkage, engine mounts, transmission mounts, radiator hoses all this should of came with the motor i might be missing something else not sure.
Old Aug 8, 2002 | 04:47 AM
Default Re: I need some swap help b18c-hatch deal (drvfast)
no all of that came with it except a ecu, but the engine and everything is a 2001 so what ecu should i get, because dont i have to convert to obd1
Old Aug 8, 2002 | 05:58 AM
Touch's Avatar
yup, you gotta convert it.
Old Aug 8, 2002 | 08:50 AM
R_yd's Avatar
is it b18c or b18c1?
Old Aug 8, 2002 | 09:03 AM
Malachi's Avatar
plug everything in and buy a obdI ecu. everything should plug in under the hood using the obdII harness.
[Modified by Malachi, 12:03 PM 8/8/2002]
Old Aug 8, 2002 | 10:36 AM
DerekY's Avatar
Like Malachi said. All you need is a OBD1 GSR ECU (p72). The engine hardness sould bolt up to your harness in the Civic. Drop the motor in, hook up the harness, plug in the P72, give it a try.
It's simple as plug and pray.
Derek
Old Aug 8, 2002 | 10:49 AM
Malachi's Avatar
Default Re: I need some swap help b18c-hatch deal (DerekY)
also in a 92 you should only have to run 1 wire. check all of them with the diagram here http://hybrid.honda-perf.org/
Old Aug 8, 2002 | 11:37 AM
Default Re: I need some swap help b18c-hatch deal (Malachi)
yea its a b18c1, ok i guess i will try to find a p72 obd1 and give it a try
b18c inside
Apr 10, 2005 07:04 PM
weakGOODJunKieS.com
16
May 20, 2002 05:15 PM
civic_sir94
Oct 24, 2001 08:14 PM
