turbo problem
ok guys i have a 1993 del sol si with a b16 swap on turbo...im running a s100 hondata ecu...the motor is mostly stock...the problem is when i get on it 1st gear picks up quick and then shift to 2nd and it still picks up but it back fires alot and it kinda lags the same on 3rd gear but after 4th it gets better...so idk what the problem is...i changed the spark plugs and it inproved a lil bit...could it be not enough gas i have 880cc injectors...it's a t3/t4 turbo kit....i use to have the whole set up on a b16 before then i took the turbo off it and got rid of the motor and now i put another b16 and i just changed the piston rings on it...but it's still the same setup...and before it never game me any problems...so if any body knows anything that can help me out please let me know...thanks
i think 880cc injectors are very large for it. did they come with the kit??? is your ecu tuned properly? if you have some backfire, see if you have any holes in your exhaust. you could be running to rich also.
No i got them afterwards...but i had the same set up i didn't change anything just hte mototr so the turbo is fine...it would run good on my old b16....there both b16a2...and my down pipe...it's short...you can hear the turbo spoil up....it doesn't connect with my exhaust
