What Can i Do withe a D16y8 ?????
Whats Going on.... !!!!!!! Just wondering what else can i do withe a d16y8 engine...???
Boosted... its 1 of my options but..
what kind of heads can work with it ????
or do i have to swap for a bigger engine??
LET ME KNOW...
THANKSSS
LET ME KNOW...
THANKSSS
just put vitara pistons, eagle rods, CTR cams, adjustable cam gears and boost it.
you will spank a nice amount of cars with that build.
unless they are like a b series turboed.
but most are not
EDIT: i forgot to say GET IT TUNED so you can really spank most cars
but most are not
what can u do with it? boost it you'll be beating most cars, if done properly
you can do anything you want to it. so some searching look over all your options. boosting is the most popular way. like they said, tune it well no matter what path you go with, NA or boost
he one need ONE cam and ONE cam gear, its a sohc lol
^^^ thats what I was about to say.
mique-Use the search tool man. There are like ideas out of this world on here. Ls swpas, GSr swaps, turboed, supercharged, NA. just read up, pick what sounds like would best suit you. GL
how? the ctr cam is a DOHC and the single cam has both intake and exhaust lobes. the ctr has a cam for the intake and a cam for the exhaust. it isnt possible to use either on a sohc.
Hey thnks for all the comments...
faaaast anwers !!
but yeah sounds good....
i love turbos... so i was thinking if i just need boosted but now i know what else do i need to put on my engine before turbo.. !!
faaaast anwers !!
my god Unseen Racer you sound like a ricer just throwing out stuff that wont even work for this guy. You seemed really confident in your post and your whole post got taken apart. ahhaha
for the OP. I think if you have the option to go boost do it. You wont regret it. Even if its on stock internals it will be so much more fun at 7psi than stock. Or if you have the cash to get some work done to boost higher that would also be good. new pistons and rods ,head gasket and head steads. You can squeeze some decent power out of that
ok just to clarify you wont be putting ctr cams in a d16 and you will only need 1 cam gear.
the vitara build has become popular and yeilds fairly good results. my buddy has a d16y8 with the vitara build running 478whp and 10.3 in the 1/4 mile.
what is your budget and goals for the car?
but DAMN!!!! 478whp on a y8!??!?!?!
NEVER heard of that.
anyways about that d16y8 vitara setup... checkout speedfactoryracing.net
my buddy own it... they have some sick ****.
11 sec k24 hatch
and dude!!!!!! thats F-ing SICK!!!!
wish my ride can be that bad azz!!
someday my friend... someday. thats what i tell myself as inspriation
yes but too much psi gives you too much power with out your engine being properly setup!
OP you should also look into getting a good clutch maybe a stage 2 or 3 depending on the power you are looking to put down... Don't get a lighter flywheel cause you don't want to loose inertia with a turbo car! I would also look at get an lsd... and the obvious some sticky tires! I figured if you are going to build it you should look at all aspect and not just the engine... everything has to work together to give you the maximum amount of power!
