F20-b swapin
Old Jan 29, 2009 | 04:46 PM
chayce's Avatar
Default F20-b swapin
Hi peeps! Im gettin ready to put the f20 in a 97 accord auto 4 door. I know probably not the ideal car but just wonderin if anyone has any tips waiting on parts i didnt order.
Old Jan 29, 2009 | 06:05 PM
Cannon Man's Avatar
Default Re: F20-b swapin
Its just like the h swap. You'd have to do anything you would usually do to convert to obd 1, source an ECU, and I believe the only came with electric p/s so there will be no p/s pump on the block. For the ECU I *believe a p13 can run it and also a p72 from the GSR. Not completely sure on that though
Old Jan 29, 2009 | 09:57 PM
erk89's Avatar
A chipped P06 will be sufficent and would allow for tuning down the line.
Old Jan 30, 2009 | 05:23 AM
Brad_and_the_acc's Avatar
--Off Topic--
lol, nice sig.
Are you planning to do a 5 speed swap when you swap in the F20b?
Old Jan 31, 2009 | 10:12 AM
alkoholikwun's Avatar
p06 non vtec ecu, which can be wired in though.
p28, best ecu to chip, vtec ready.
while your at, if you got the money for it, i'd buy some aftermarket parts for it, basic intake, header, exhaust. get new motor mounts if needed. while the motor is out, you can replace timing belt if you want.
Old Jan 31, 2009 | 10:17 AM
Crono139's Avatar
http://www.accordracing.com/showthread.php?t=5649
lrch26
Mar 29, 2007 05:19 PM
zenon8890
Nov 25, 2005 06:34 PM
91d15bvtec
Aug 30, 2004 06:02 PM
hybridmoose
Apr 24, 2003 03:50 PM
