NEwb question : type R or GSR or SIR stock intake fitment on b16a2
Old Jan 29, 2009 | 04:13 PM
ek_student's Avatar
Default NEwb question : type R or GSR or SIR stock intake fitment on b16a2
Was wondering besides the sir stock intake if either the gsr or the ITR will fit on my b16a2 ? or can i use the arm from the sir intake with the air box form a gsr or itr , id really not like to have that giant lunch box for an air box if i can avoid it help would be much appreciated and yes i know an aftermarket intake are better but down the road id like to get a spoon elbow can someone elaborate on what i can do with this
Old Jan 29, 2009 | 04:22 PM
ek_h22's Avatar
Default Re: NEwb question : type R or GSR or SIR stock intake fitment on b16a2
I dont think it will work the intakes are different castings.
Old Jan 29, 2009 | 04:23 PM
del slw's Avatar
type Ri is your best bet, gsr wont fit as well. but the type R will also be too big for the throttle body
but neither will give you impressive power gains, so why bother at all?
Old Jan 29, 2009 | 04:38 PM
geebs's Avatar
The B18C1 intake manifold has a different bolt pattern than the B18C5 or B16A.
Also the intake arm from the B18C1 wont fit because the throttle body sits slightly lower.
Old Jan 29, 2009 | 04:45 PM
Agent_EM1's Avatar
I'm pretty sure ITR may fit.
Old Jan 29, 2009 | 04:50 PM
Deetz's Avatar
Crazy Honda Guy
Ok....
the gsr won't fit
the itr will, but you will loose power
the 2nd gen B16 (P30) makes the most power on that engine!!
Old Jan 29, 2009 | 04:58 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Why would the ITR intake cause you to lose power? Last I checked, larger intakes always cause a power gain on B series engines.
The ITR's arm may not fit as the ITR's TB is bigger. But it's the right shape. The GSR's arm is the wrong shape.
Why don't you buy an EBAY intake or something?
Old Jan 29, 2009 | 04:59 PM
ek_student's Avatar
wat about the sir arm with a type R intake box ? i jsut dont want a huge cluncky box in my engine bay
Old Jan 29, 2009 | 05:28 PM
EK TUNER's Avatar
The OEM ITR intake box is exactly the same as the ones found in other Integras. If anything, you want to get the ITR intake arm and resonator box and piping. Those are the two parts of the intake system that was redesigned on the ITR. The ITR intake arm is 3" which is the same size as many aftermarket intake arms. Just clamp it tighter at the throttle body since the B16 TB is not as big as the ITR TB. The resonator on the ITR was redesigned to pull cold air from outside the Integra bay. If you take apart the stock ITR resonator, you can use the snorkel-like piping inside to snake the intake tube under the passenger's fender. You will need to custome mount the piping, but you will pretty much have a poor man's Comtech Ice Box.
If you're interested in modding the stock ITR intake, you can even make yourself a poor man's Mugen CAI. Check it:
https://honda-tech.com/forums/showth...ght=itr+intake
clem kevin
Feb 11, 2008 03:01 PM
EFinawesomeman
Jun 2, 2007 02:23 PM
97teg415
Sep 17, 2004 06:51 PM
typer.org
Oct 14, 2002 04:08 AM
GsrSdn
Feb 9, 2002 08:59 AM
