Idle Problems
Old Jan 29, 2009 | 02:13 PM
dth0ng69's Avatar
Default Idle Problems
Hey I have a 96 civic LX with a automatic transmission.
when I drive for a while, my idle sometimes drops down to around 3000 and shakes mroe when i'm on D
when I Put it on neautral it raise up a little and stops shaking.
Would adjusting the idle set screw work?
I was reading around and would cleaning out IACV help smooth out my idle? If so how would i do so?
Old Jan 29, 2009 | 02:16 PM
philosofy1's Avatar
Default Re: Idle Problems
you can adjust the idle screw and most likely it will work, but that's the short cut.
clean out you TB, when was the ast time you replaced the fuel filter and air filter.
Old Jan 29, 2009 | 02:30 PM
jeremyrocksursox's Avatar
heres how to clean out your IACV: https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/ but i would recommed doing what philosofy1 sayed too
Old Jan 29, 2009 | 04:45 PM
Mangotreemechanic's Avatar
If you are driving and the engine rpm is over 3000, then you are having more than idle problems. If your rpm drops down to 3000, then something is cutting out, fuel or some sensor is telling the ECU to drop the rpm. Get a reading out of the OBDII reader.
The idle adjusting screw only works at idle (no pressure on gas pedal). Same with the IACV.
axis11
May 16, 2013 08:16 PM
SHG_James
Feb 13, 2009 04:40 PM
shadycrx
Feb 22, 2006 03:08 PM
DC2*Integra
Sep 20, 2005 12:51 PM
ArchAngel Sabastian
May 18, 2002 10:44 AM
