Fuel Filter & Thermostat?
Old Jan 29, 2009 | 09:31 AM
PinoyDelS0l's Avatar
Default Fuel Filter & Thermostat?
If i change my fuel filter in my del sol, what good will that do? And if i change the thermostat will that bring more hot air into my car?
Old Jan 29, 2009 | 09:34 AM
Mashimaro's Avatar
Default Re: Fuel Filter & Thermostat?
it's all part of maintaining your delsol. why change an airfilter? why change oil? why change spark plugs? it's all to keep your car running well.
changing thermostat can bring more hot air into your cabin if your current one is dead..but that may only be a small part of the problem if you're getting no heat.
Old Jan 29, 2009 | 10:21 AM
CountDracura's Avatar
Your fuel filter traps unwanted particles from entering your fuel system. Changing it will promote the longevity of your engine and possibly achieve high gas milage if it hasn't been replaced in a long time. It's very easy to do, just make sure that before you begin, you remove the fuel cap in your fuel door to relieve the line pressure.
Old Jan 29, 2009 | 05:33 PM
alrightyyyy thank you fellas!!!
csckwade
Dec 28, 2012 11:01 AM
Jayk00CivicEx
Mar 29, 2012 10:49 PM
martn53
Nov 10, 2009 01:24 PM
Understeer
Nov 19, 2005 07:09 PM
