smog ?
the complete motor swap?
Or are you going to keep your intake and exhaust manifold?
Either way, if the smog tech looks at the block code you fail visual.
If he doesn't then you can most likely pass without a hitch.
Any legal engine swap requires a full swap from the ECU to the exhaust. The swap you are doing is very common and can easily be done as to not throw codes. It would then requre a visit to the ref.
Efbucket
14
Oct 5, 2007 03:14 PM
Achenar
Aug 6, 2004 08:04 PM
