rear camber washer trick
Old Jan 29, 2009 | 09:01 AM
freakasis's Avatar
Default rear camber washer trick
everywhere i find tells me how many washers will correct how many degrees. but this tells me NOTHING because not all washers are the same thickness.
does anyone know how many inches or mm of washers will correct how many degrees?
Old Jan 29, 2009 | 09:24 AM
Mashimaro's Avatar
Default Re: rear camber washer trick
trail and error dood!
put on some washers, eyeball it, take it to an alignment place and add or subtract until you get the camber you're looking for.
Old Jan 29, 2009 | 05:11 PM
Bondito007's Avatar
I don't know how many millimeters equals how many degrees. But I would take a guess and say that by the time you figure it out you will have spent enough money(between trips to the alignment shop) to have bought a camber kit. Short cuts aren't always smart cuts. Good luck.
jdmdohcek98
Suspension & Brakes
Jan 13, 2008 06:35 PM
nindoo
Honda Civic (2006 - 2015)
Jul 30, 2007 08:23 AM
phuster
May 10, 2005 09:19 AM
austrian type-R
Jul 23, 2003 07:42 AM
darkknightwong
11
Sep 18, 2002 09:41 AM
