timing belt tensioners honda accord 2001
Old Jan 28, 2009 | 11:08 PM
anahiem714's Avatar
Default timing belt tensioners honda accord 2001
how would i know if i had a bad belt tensioner?
the reason is that that pushed the tensioners to create tension and i did not follow the directions. Now i have to redo the timing belt change because of the whining noise.
Old Jan 29, 2009 | 03:42 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: timing belt tensioners honda accord 2001
just spin the tensioner. if it feels loose or makes rattle sounds then replace it. if you aren't getting the tension you feel you should you can try replacing the spring.
Space Odyssey
Jul 6, 2018 08:53 PM
jsqu03
Jul 11, 2014 01:37 PM
tat2dgrl8
Oct 22, 2012 06:36 PM
