? for those w/ itr cams
Old Aug 7, 2002 | 05:17 PM
Black B16A's Avatar
Default ? for those w/ itr cams
I have itr cams installed in my b16 and I was wondering what are your cam gears set to. Also, let me know if these setting were set by the dyno or the butt dyno. Thanks for your replies.
Bryan
Old Aug 7, 2002 | 05:47 PM
bryant's Avatar
Default Re: ? for those w/ itr cams (Black B16A)
Every car is different, Same with every motor. you not going to get good power if you go off somone elses mods. Get on a dyno and mod your car for you.
Old Aug 7, 2002 | 10:45 PM
Black B16A's Avatar
Default Re: ? for those w/ itr cams (CR-X)
My car went to the dyno today but the cam gears are still set at 0 on both cam gears. I was just wondering what everyone else was getting not the I want to set the gears off of someone elses settings.
Old Aug 8, 2002 | 12:20 PM
ILUVTEC's Avatar
A (real)dyno would be your best bet man, but for starters, try starting to advance the intake and retard the exhaust a couple degrees. Every car with different mods on them(different Air & Fuel mods/mixtures) will react a bit differently. But in general maybe adavanced a few degrees on the intake side and retarded a couple on the exhaust side might yield some good mid and high rpm punch without loosing too much down low. But then again, your car may very well be different, and I have more knowledge of the B18 vs the B16, but they are so close these respects. Enjoy
JDAMC
Mar 8, 2007 05:14 AM
newskoolhatch
Apr 1, 2003 02:41 PM
crxgurlllll
11
Feb 28, 2003 09:11 AM
kefka
Apr 15, 2002 07:42 PM
Petah
Nov 26, 2001 11:40 AM
